O2 sensor went bad only after 20k miles?
Old Feb 1, 2002 | 10:45 AM
ITR 2K's Avatar
Default O2 sensor went bad only after 20k miles?
Aren't these things suppose to last up to 100k miles? My ITR only has 20k on there, and I already need a new one. I'm talking about 20k non beating on miles. A bunch of normal driving, and some beating. Now I have to get it fixed, because it's causing my fuel to run lean. Does anybody know the life expectancy on an O2 sensor?
Old Feb 1, 2002 | 10:56 AM
sgT's Avatar
sgT
Default Re: O2 sensor went bad only after 20k miles? (ITR 2K)
i doubt its your o2 sensor.
what mkes you think that
Old Feb 1, 2002 | 01:11 PM
ingrate's Avatar
25 Year Member
i was under the impression that a bad o2 sensor would make the car run rich to be safe?
Old Feb 1, 2002 | 01:13 PM
sgT's Avatar
sgT
Default Re: O2 sensor went bad only after 20k miles? (In7egrity)
check engine light would also come up
Old Feb 1, 2002 | 02:03 PM
mickey513's Avatar
A bad o2 sensor will make your car run rich.
Old Feb 2, 2002 | 10:18 AM
ITR 2K's Avatar
Default Re: O2 sensor went bad only after 20k miles? (sgT)
I know it's the O2, because it has that distinctive smell. Also, my buddy owns a garage, and he threw it under a scanner. The check engine light also came on. I was also under the impression that a bad O2 will make your car run rich. But my Air Fuel guage is reading lean, very lean. But it's all good now, it's running fine, and everything is fixed.
Old Feb 2, 2002 | 11:25 AM
py1188's Avatar
I had a defective cat and a defective O2 after 7k miles.
All replaced by Acura
odishaw
Feb 16, 2008 08:34 AM
boost fed ls
Aug 31, 2004 07:45 PM
hondave
May 2, 2004 09:36 PM
projectM
Dec 13, 2002 07:57 AM
