1993 honda accord fan
So i checked my car today and i was looking and well one of my fans wasn't spinning, the right side if u look at the car directly in front of u, is this normal or is my fan dead, the car was in park at 900-1100 RPM, its a 1993 honda accord AT (automatic), stock everything, it is the fan that sits behind the radiator or a/c
if you are looking at car from the front then the right side fan is your a/c condensor fan,,, quick test get a big screwdriver abd hit the center backside of the fan don't hit the fins if fan comes on you got a bad motor ,,if it does not could be fuse, relay, wiring ,,,the is a fuse in the underhood fuse box condensor fan if it is not the motor make sure that fuse is ok
both fans need to come on to properly cool your engine,,at least do the test i suggested that way you mihgt have an idea on whats going on eck it might just be a fuse
2Cleezy
Sep 2, 2005 08:48 AM
89_honda_accord
Jun 15, 2005 08:55 PM
