p0780 accord "Problem in Shift Control System"
Old Apr 28, 2005 | 11:51 AM
alsarabi's Avatar
Default p0780 accord "Problem in Shift Control System"
I'm getting code p0780 "Problem in Shift Control System" for 2001 automatic accord. Does this mean the clutches in the transmission are bad? I need suggestion please as I cannot think where else to start.
Thanks!
Old Apr 29, 2005 | 01:23 PM
deserthonda's Avatar
i doubt your clutches are bad ...first thing i woud do is remove the lock-up control solenoid/valve shift control solenoid clean out passages sometimes screen get clogged ,,put back together clear code and test drive
Old Apr 29, 2005 | 03:46 PM
metric's Avatar
Default Re: (deserthonda)
how many miles are on it?
Old May 30, 2005 | 01:11 PM
daver's Avatar
Default Re: p0780 accord "Problem in Shift Control System" (alsarabi)
did you get it fixed?
Old Nov 30, 2006 | 03:22 PM
honda genome
Guest
Posts: n/a
Default Re: p0780 accord "Problem in Shift Control System" (daver)
did u fix this or what, similar prob. here....
Old Nov 30, 2006 | 06:54 PM
hondadude's Avatar
Extended warranty
mina
Dec 28, 2017 09:55 AM
Ruizj2195
Sep 9, 2017 06:31 AM
garbagehonda
Sep 17, 2010 03:12 AM
espedito
Jan 4, 2010 02:45 PM
