Best Header Design for Nitrous Motors.
Old Apr 28, 2005 | 10:56 AM
Rocket's Avatar
Default Best Header Design for Nitrous Motors.
Best Header Design for Nitrous Motors?
Just curious as to what our header experts reccomend.
Old Apr 28, 2005 | 11:13 AM
six sigma racing's Avatar
Default Re: Best Header Design for Nitrous Motors. (Rocket)
what size motor?
Old Apr 28, 2005 | 12:24 PM
Rocket's Avatar
Default Re: Best Header Design for Nitrous Motors. (DTR-FAB)
2.0L Running to 9 - 10K rpms in most gears.
Old Apr 28, 2005 | 12:31 PM
4-1 header 1 3/4 port 12" step to 1 7/8 13" if it was NA i would do a 20 degree 2 1/4 collector throat but id might try a 2 3/8. with a 2 3/4 transition and straight pipe...
then again there could be many different setup that might work... this is what i would run personally
Old Apr 28, 2005 | 01:08 PM
Rocket's Avatar
Very coo. So about 25" Primaries with the piping sizes you reccommend and a fairly angled collector with the appropiate sized outlet to inlet ratio.
You think shorter primaries would be good since you just want to get the extra hot gases out quikcer.
Old Apr 28, 2005 | 01:22 PM
5thgenallmotor's Avatar
I am also interested in this discusion. Does anyone make a "nitrous" designed header?
Don't most V8 guys go with huge primary 4 to 1 design?(Gotta get it out fast)
Modified by 5thgenallmotor at 5:37 PM 4/28/2005
Old Apr 28, 2005 | 02:16 PM
yeah you can go a little shorter..22-23 would be the shortest i would go..
Old Apr 28, 2005 | 02:48 PM
cubish's Avatar
some good info. im looking into a header for my nos car, my mugen header isntt cutting it
Old Apr 28, 2005 | 02:50 PM
hybrid_vtec's Avatar
I have seen a lot of guys use short primary 4-2-1 exhaust manifolds on supercharged and N2O cars, however I used a 4-1 long primary design when I ran N2O and didnt notice much of a difference.
Old Apr 28, 2005 | 05:19 PM
Phase Change Racing's Avatar
Default Re: Best Header Design for Nitrous Motors. (5thgenallmotor)
Now you're speakin my language. Yes, 99% of the v8 guys (like myself) are running a 4 into 1 header. There are a couple companies that make 4-2-1's and stuff but they are usually small tubes and a gimmick for the most part.
My advicd: Go big. I dont' think the design is going to matter a whole lot either way, but go big on the primaries, big on the collector, and even bigger on the exhaust system (if you are going to run one). Nitrous creates vastly more exhaust volume/energy and it needs to get out (also the reason turbo motors LOVE nitrous). The easier the engine can get the exhaust out, the easier it can get more nitrous in. IMO the small drop in torque is a worthy sacrifice for the power gain while on the bottle.
Old Apr 28, 2005 | 05:35 PM
JSpin's Avatar
Default Re: Best Header Design for Nitrous Motors. (Phase Change Racing)
bump for a fresh topic here on HT
Old Apr 28, 2005 | 11:15 PM
RMF
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DTR-FAB &raquo;</TD></TR><TR><TD CLASS="quote">4-1 header 1 3/4 port 12" step to 1 7/8 13" if it was NA i would do a 20 degree 2 1/4 collector throat but id might try a 2 3/8. with a 2 3/4 transition and straight pipe...</TD></TR></TABLE>Took the words right out of my mouth.
With nitros the header still does what its supposed to do.Its sounds funny ,But the louder the motor is over its stock sound ,The shorter the primaries need to be: Now can anybody tell me why?
Old Apr 29, 2005 | 03:13 AM
PyroProblem's Avatar
Default Re: Best Header Design for Nitrous Motors. (RMF)
Is it because the louder it is, the more compacted the exhaust waves become and thus creating a restriction if it isnt dumped to atmosphere fast enough?
Old Apr 29, 2005 | 09:00 AM
whatVTEC's Avatar
then again there could be many different setup that might work... this is what i would run personally</TD></TR></TABLE>
how much would a header like this cost?
jkalex05
Aug 27, 2009 09:23 AM
Project-D
Feb 10, 2008 10:38 AM
ONE SLOW EG
Apr 2, 2003 05:52 PM
vtec_outlaw
Dec 8, 2001 12:38 AM
2fastGSR
Oct 2, 2001 12:53 PM
