Identifying USDM ITR header?
Old Apr 28, 2005 | 08:57 AM
spectacle's Avatar
Default Identifying USDM ITR header?
What (if any) markings on the header tell me if it is a Type R? My friend gave me one but I'm not sure if it is or not. Not a big deal...just one of those things.
Thanks
Old Apr 28, 2005 | 10:27 AM
spectacle's Avatar
Default Re: Identifying USDM ITR header? (spectacle)
anybody?
Old Apr 28, 2005 | 10:50 AM
Bbasso's Avatar
Maybe this would help ???
Old Apr 28, 2005 | 11:06 AM
Willard's Avatar
lower 1/2 and cat are here.
Old Apr 28, 2005 | 11:35 AM
spectacle's Avatar
Default Re: Identifying USDM ITR header? (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">
Maybe this would help ???</TD></TR></TABLE>
so all USDM ITR header have "OK11" in the corner right there? mine says "9M28"
Old Apr 28, 2005 | 11:37 AM
Bbasso's Avatar
I dunno, the one I have says that...
Old Apr 28, 2005 | 12:31 PM
ebelp's Avatar
Here's mine...I'll check to see what mine is labeled with when I get home...
btw, does anyone know what that bracket piece is for? (rusty piece on my stock manifold there that's leaning against the brick) I can't figure out what it's for...
Old Apr 28, 2005 | 12:53 PM
B2FiNiTY's Avatar
That bolts up to the block.
Old Apr 28, 2005 | 12:58 PM
BlueR's Avatar
Default Re: (B2FiNiTY)
the stock, cast iron exhaust manifolds are really heavy so there's a few brackets that bolt on to various places for support...
most aftermarket SS headers are so light that those braces/brackets are not necessary
Old Apr 29, 2005 | 04:15 AM
spectacle's Avatar
Default Re: (BlueR)
up for anymore suggestions
Old Apr 29, 2005 | 04:17 AM
Willard's Avatar
Default Re: (spectacle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spectacle &raquo;</TD></TR><TR><TD CLASS="quote">up for anymore suggestions</TD></TR></TABLE>
the number on the casting is not that big of a deal. as long as the lower 1/2 looks like the one in the picture... it is a UDSM ITR header.
Old Apr 29, 2005 | 09:11 AM
Padawan's Avatar
Darth ModerVader
Default Re: (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">the number on the casting is not that big of a deal. as long as the lower 1/2 looks like the one in the picture... it is a UDSM ITR header.</TD></TR></TABLE>
Exactly. As far as I could tell when I compared a couple of B-series upper manifold sections to the ITR piece, they're all identical. The only real difference is in the lower section.
Old Apr 29, 2005 | 02:27 PM
spectacle's Avatar
Default Re: (Padawan)
what's different about the bottom section?
Old Apr 29, 2005 | 02:37 PM
Padawan's Avatar
Darth ModerVader
It is supposedly a higher-flowing design.
Old Apr 29, 2005 | 09:17 PM
TheGSRGuy's Avatar
Look for the shield covering the bottom section near the collector.
Old Apr 29, 2005 | 10:19 PM
KOALA YUMMIES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly. As far as I could tell when I compared a couple of B-series upper manifold sections to the ITR piece, they're all identical. The only real difference is in the lower section. </TD></TR></TABLE>
Yep, I measured the diameters of the holes, spacing, length, width blah blah all the basic measurements compared to a stock GSR upper cast exhaust manifold and they were identical. I ended up cleaning it up and using it since the prev owner stripped out the upper heatsheild bolts while returning to stock.
The difference is in the lower half of the exhaust manifold.
This part:
RTW
Apr 16, 2007 10:15 AM
SlowEgg
Sep 24, 2006 08:57 AM
smooz EK
Aug 1, 2006 07:50 AM
YellowSpeed
Mar 5, 2002 01:55 PM
ckkl
Nov 23, 2001 04:30 PM
