Washer trick bolt sizes/specs (correct your camber with washers)
Old Apr 28, 2005 | 08:20 AM
90gs's Avatar
Default Washer trick bolt sizes/specs (correct your camber with washers)
I've had 2 DA's, a DC, and a EG.
the first DA i didnt lower, the second one i didnt care about camber, the third one wasnt lowered enough to matter, and now the EG has expensive tires so i want to correct the rear camber (front is already corrected)
now i know on the DAs you could put washers under where the control arm attaches to the body (i think... i know what it looks like but i'm not sure what its called)
can you do this with EGs as well? if so, do i need longer bolts like you do with the DAs? if so... if anyone has done this could you let me know what bolt size and how many washers i should put.
Old Apr 28, 2005 | 08:22 AM
Luserkid's Avatar
Default Re: Washer trick bolt sizes/specs (90gs)
Most honda's are the same way (well integra and civics i mean) You do the same trick as you would with the DA. But sorry i dont know the bolt sizes.
Old Apr 28, 2005 | 08:29 AM
tony's Avatar
hey i'm going to do this tmrw here is a link that will help
http://home.earthlink.net/~civ....html
Old Apr 29, 2005 | 02:13 AM
fizeks's Avatar
could u do this to the front camber also?... i need to do the rear ones badly . after i saw the guys pics on the link .. his tires were straight on the back.. omg.. u should see how bad mine are.
Old Apr 29, 2005 | 04:19 AM
tony's Avatar
no you can't do this to the front you need to buy a camber kit
Old Apr 29, 2005 | 09:21 AM
90gs's Avatar
Default Re: Washer trick bolt sizes/specs (tony)
going out to buy the bolts now..
four 10 x 1.25 x 45mm bolts
and 1 washer for every inch drop (2 per side for every inch)
Old Apr 29, 2005 | 09:25 AM
suspendedHatch's Avatar
You don't need longer bolts just for one washer. I doubt you need it for two, but I haven't tried it.
Don't take the camber all the way down to zero. Leave it between -.5 and -1 degrees.
ek fan
Oct 11, 2008 06:50 PM
huge230
Nov 26, 2006 09:47 AM
chestnut_55
Dec 28, 2005 11:26 PM
X2BOARD
Sep 6, 2001 12:52 AM
X2BOARD
Sep 5, 2001 09:14 AM
