I YI YI YI YYYIIIII Brake Booster extraction
Old Apr 28, 2005 | 07:15 AM
fobile missile's Avatar
Default I YI YI YI YYYIIIII Brake Booster extraction
AAARRRGGGHHHHH, I can't get any tool onto the upper driver side brake booster nut. I will cry...now....WWWAAHHHHH!!!!
I have a 91 std hatch. I have practiced double flaring with junk yard brake pipes. I have started the rebuild of the CRX rear disc assemblies that I obtained. Caliper rebuild, brembo blanks, new bushings for the compesator/ rear assembly bushing and the lower control arm bushings. I have the sway bar, also.
If I cannot extract the brake booster nuts then I will not proceed. D.O.A.
I YI YI YI YYYIIIII !!!!!!!!! HHHEEELLLPPP!!!!!!!
Snailor Built
Apr 20, 2015 10:07 AM
The Hooligan
Jun 21, 2005 06:40 PM
