aWD vs. 2WD in Drag racing
Old Apr 28, 2005 | 12:51 AM
HondaRacer18's Avatar
Default aWD vs. 2WD in Drag racing
So how does AWD compare to 2WD in drag racing? any opinions?
Old Apr 28, 2005 | 01:07 AM
SEFIxCivic's Avatar
Default Re: aWD vs. 2WD in Drag racing (HondaRacer18)
i think awd cars a prone to breakage, once they start getting past the 12's. thing about the awd cars is that there are so many pieces in the drivetrain... and all of them are expensive.
if you think a 500 b series tranny is expensive... wait till you price out an evo transfer case... it runs about 2 grand new, and they are hard to find used.
it might sound like i'm bagging on awd... but i just telling it how it is. my daily driver is awd, and i have no intentions of taking it to the drag strip.
Old Apr 28, 2005 | 01:35 AM
Default Re: aWD vs. 2WD in Drag racing (SEFIxCivic)
cool thanks, other than that how do you think they would be?, good or bad? just for general dragging purpose? Are they quicker off the line or any little things like that?
Old Apr 28, 2005 | 02:10 AM
SEFIxCivic's Avatar
launching an awd car requires finesse, if you don't give it enough rpms the engine will bog down. if you can launch an awd correctly, they simply cannot be beat providing that you guys are both on street tires.
Old Apr 28, 2005 | 02:31 AM
cool so say i were gonna get a talon would it be better to go 2wd then to awd or vice versa or stay 2wd
Old Apr 28, 2005 | 03:19 AM
TyCooley's Avatar
my friend has a evo and he just wrecked his transfer case the other week at maple grove. has 300hp and the cost to replace was 2500 i believe. under warranty or whatever but they won't do it again cuz he has aftermarket clutch
Old Apr 28, 2005 | 03:22 AM
Default Re: aWD vs. 2WD in Drag racing (TyCooley)
damn! that blows but nice evo.
Old Apr 28, 2005 | 03:23 AM
Is that evo quick?
Old Apr 28, 2005 | 08:37 AM
TyCooley's Avatar
consistant 12.4s that day that it broke
Old Apr 28, 2005 | 07:02 PM
cool.
Old Apr 28, 2005 | 08:28 PM
92LSVTEC's Avatar
i have a friend who is a DSM lover, and he works on a lot of the AWD cars in the area, and he is almost always replacing rear diffs.... one guy broke his rear axle launching at 4500, awd is better street tire to street tire, but at the track, on my slicks my 60 foot times are about as good as the street tire AWD friend of mines
Old Apr 29, 2005 | 03:12 AM
shotty's Avatar
Default Re: aWD vs. 2WD in Drag racing (92LSVTEC)
All wheel drive will get you off the line faster on the street, but at the track where you can throw on some slicks on your fwd, thats different. The drivetrain loss at the end of the track with awd will just slow you down.
Old Apr 29, 2005 | 03:16 AM
PM-Performance's Avatar
Yea AWD requires some work. You might think its easy becuase its AWD, but they break alot easier. And yes they are more expensive to fix and find parts for most of the time.
But man when they hook and dont break , they hook hard
Its the initial shock that breaks ****. 2wd or AWD, same thing breaks them
Everything has its ups and downs
Ty , was that Brent that broke? Just curious
Old Apr 29, 2005 | 06:37 AM
ROOROWNS's Avatar
i have been driving my 1990 GSX eclipse for 9 months and i am just learning the correct way to "launch" the car. Lemme tell you that it sounds easy but hop in any AWD turbo 5 speed car and give it a try you will be surprised at how hard it is to do it Correctly. But when it is done right forget it AWD owns in take off.
Sean
Old Apr 29, 2005 | 09:15 AM
Default Re: (EG_Black_Hatch)
sounds awesome, great info.
Old Apr 29, 2005 | 09:19 AM
TyCooley's Avatar
Default Re: aWD vs. 2WD in Drag racing (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">Yea AWD requires some work. You might think its easy becuase its AWD, but they break alot easier. And yes they are more expensive to fix and find parts for most of the time.
Ty , was that Brent that broke? Just curious</TD></TR></TABLE>
yeah it was brent
Old May 2, 2005 | 01:20 PM
90LSB20's Avatar
My race car is an all wheel drive eclipse it was a gst but I converted it to all wheel it is a lot better. but a stock transfer case and rear diff is a little week but still can run 11 on stock drive train. just like any race car part's are bound to break and yes DSM break down a lot but make a lot of power with very little money
My friend's stock GSX Run high 12 with only 1000.00 in to the car and that is not Nos.
I would like to add i love my Dsm But Honda is more reliably
Old May 2, 2005 | 01:26 PM
90LSB20's Avatar
But eclipse front wheel drive car's trans suck i went . through 2 trans in 3 month's the diff cant handle power at all. My friend Gstwent through 6 trany in 8 month's front wheel is not worth it
Old May 2, 2005 | 01:54 PM
b18CrxSi91's Avatar
71.179.86.205
Default Re: (90LSB20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90LSB20 &raquo;</TD></TR><TR><TD CLASS="quote">But eclipse front wheel drive car's trans suck i went . through 2 trans in 3 month's the diff cant handle power at all. My friend Gstwent through 6 trany in 8 month's front wheel is not worth it</TD></TR></TABLE>
You failed english didn't you?
awd &gt; 2wd (on the street)
Old May 3, 2005 | 06:54 AM
90LSB20's Avatar
how did you no haha but ya i suck at english but good with math and Mechanic work
Old May 3, 2005 | 08:20 AM
TurboMiata's Avatar
On street tires,
AWD &gt; 2 wheel drive
At the track,
2WD &gt; AWD
Why? Because there are always wider slicks, there isnt always a stronger AWD driveline. To add to that, if a car is fast enough to lift the wheels off the ground, AWD is pointless and only adds weight. (this assuming comparing RWD to AWD)
Typical 60ft on awd street tires is a 1.7 around here from what I can tell.
Old May 4, 2005 | 02:06 PM
90LSB20's Avatar
Default Re: (TurboMiata)
1.7 may be for a stock car or lightly moded. My friend's Talon run 1.5-1.6
on street tires. with street slick's allwheel drive can run 1.3-1.4. its realy all about the set up. if you are useing 2 step you can get you 60 foot down a lot
Old May 5, 2005 | 05:06 AM
TurboMiata's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90LSB20 &raquo;</TD></TR><TR><TD CLASS="quote">1.7 may be for a stock car or lightly moded. My friend's Talon run 1.5-1.6
on street tires. </TD></TR></TABLE>
hmm...if thats the case noone around here in an AWD car knows how to drive. (which isnt outside the realm of possibility)
1.3-1.4 has GOT to be lifting the front wheels off the ground though surely...
Old May 5, 2005 | 11:05 AM
cwin's Avatar
all wheel drive is awsome for off the line, but liike said up top put slicks on fwd an its good on the track as awd. ive got a 02 wrx an stripped first gear an broke an axle. well i htink i did still tryin to figure out exactly. but once you can launch awd its feakin awsome the pull off the line is crazy
Old May 9, 2005 | 08:55 AM
90LSB20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboMiata &raquo;</TD></TR><TR><TD CLASS="quote">
1.3-1.4 has GOT to be lifting the front wheels off the ground though surely... </TD></TR></TABLE>
well Shep comes close to lifting his front tires but it does not look like he does
8.718@166.250 1/4 5.706@126.970 1/8 1.336 60 foot Look on shepraceing.com
this is a street class car run's a 1.336 60 foot i don't think he lift's the front up
