Help with Ingalls camber kit for my poor R...
Old Feb 1, 2002 | 09:10 AM
SpoonFed's Avatar
Default Help with Ingalls camber kit for my poor R...
An buddy of mine who is an Acura tech and I installed the Ingalls camber kit 3 weeks ago, I have the kit that which mounts to the ends of the "A" arm and you can adjust it 1-3 degrees...After we installed it, he gave me an alignment at Acura and everthing was perfect until we rechecked it, the balljoint had was seperated from the "A" arm about 1/2 in. and I believe the top of the "A" arm or balljoint ipoo pooing the top where shocks mount in the engine bay making a bubble type appearance, almost busting through the metal. So far it has knocked off all the yellow paint in that section and there is a bump there on both sides... I got it aligned again but still did the same thing and we raised the car having a one finger gap all around but still is doing the same thing... Another thing is when I raise and lower the car there is an awful rubbing of the plastic wheel well noise and it stops after the two front tires are off the ground...I dunno if the whole "A" arm ipoo pooing the top or what.... Your suggestions are greatly appreciated.....thanks
Old Feb 1, 2002 | 09:26 AM
sgT's Avatar
sgT
Default Re: Help with Ingalls camber kit for my poor R... (spoonfed)
you cant move the a-arm too far out or it will contact the car.
camber kits to correct negative camber are BAD and NOT NECESSARY.
take them out.
I had that problem as well as a problem destroying the inboard joints
on my axles because the camber kits stretched the axle out too far.
Trust me, they arent needed for anything 2.5 degrees or less
Old Feb 1, 2002 | 09:29 AM
tjtruong's Avatar
New User
Default Re: Help with Ingalls camber kit for my poor R... (sgT)
if you you move your a-arm out alot, it will contact with the body. a solution to it would be to sort of sand the corner edges of the a-arm around the ball joint. I've done it before because i need just a little more clearance. It will help, but when you have to do this, you know your car is too low.
tj
Old Feb 1, 2002 | 10:09 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
It took me a while to figure out what "ipoo pooing" is lol. [<---- edited]
take them out.
I agree. Camber kit should not be used for "correcting camber". It should be used to dial in the camber according to your driving preference. It should not be used as a correction, like having camber is wrong.
[Modified by Wai, 1:13 PM 2/1/2002]
Old Feb 1, 2002 | 10:11 AM
Reid's Avatar
Global Moderator
Default Re: Help with Ingalls camber kit for my poor R... (Wai)
He meant to say "ipoo pooing" but he typed "ipoo pooing" so the smart filter turned poo pooing into "poo pooing" lol!
Your post was much more amusing.
Old Feb 1, 2002 | 10:13 AM
Wai's Avatar
Wai
Default Re: Help with Ingalls camber kit for my poor R... (Reid)
Yeah that filter is just too sensitive. I couldn't even use $ in place of S.
shackler
Dec 31, 2006 09:46 AM
LagunaSecaEG
11
Sep 3, 2006 07:01 AM
strsi
Suspension & Brakes
Sep 12, 2005 12:32 PM
95_Honda_Civic
Mar 29, 2003 02:12 PM
