Help! Starter Problems
Old Apr 27, 2005 | 11:14 PM
PuiPui's Avatar
Default Help! Starter Problems
Hi, my car wont start up for me at all, it was fine this morning, started right away and now it wont start at all
what it does when i turn the key is click and sound like theres not enough juice to start it, kind of like when your battery is dead. I've tried jumping the car with another car and it does the same thing.
the clock didn't stop or anything so the battery didn't die. any one know what could cause this? a bad starter perhaps? i didn't realise they would just die like that.
b16a2 motor converted to obd1
Old Apr 29, 2005 | 10:35 AM
PuiPui's Avatar
Default Re: Help! Starter Problems (PuiPui)
just installed a new starter and battery and the same thing is happening.
it seems like the starter needs more power then it should to crank, if i hook it up to a external booster i have to crank it up quite a bit.
any ideas??? getting desprate here!! PLEASE HELP
Old Apr 29, 2005 | 10:37 AM
fasthatchb18c1's Avatar
did you ground the starter to the car frame?
Old Apr 29, 2005 | 10:46 AM
PuiPui's Avatar
Default Re: (fasthatchb18c1)
going to bum a ride to the shop to try that now, any more ideas? sorry i'm kinda irritated because i need the car to start my new job tommrow
Old Apr 29, 2005 | 10:50 AM
not really I just know that when i hooked up my starter and didnt ground it I had the same result (looked like the battery was almost dead).
Old Apr 29, 2005 | 11:08 AM
PuiPui's Avatar
i'm going to for sure go and check the grounds and ground the starter. Isn't the starter already grounded to the tranny?
takes alot of power to start the car right now and i'm sure its something dumb like that.
Old Apr 29, 2005 | 11:11 AM
no there is a wire coming from the starter connecting to the side of the car
Old May 5, 2005 | 02:32 PM
ss20gsr's Avatar
let me know how it goes, i have the same problem
Old May 5, 2005 | 03:27 PM
whitecat31's Avatar
Default Re: (ss20gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ss20gsr &raquo;</TD></TR><TR><TD CLASS="quote">let me know how it goes, i have the same problem</TD></TR></TABLE>
Do you?
Sometimes, problems seem the same, but they might not be.
It does seem like both of you might have an engine ground problem.
Both of you should try to follow this flow chart. It has worked wonders for me in the past.
http://www.nutzandboltz.org/Se...t.pdf
DriveSlowHomie
Jan 26, 2010 10:31 PM
topp_dawg_g
Oct 12, 2008 10:42 AM
jorge59la
Sep 16, 2007 06:28 PM
Integra_drk
Dec 27, 2006 10:19 AM
RCautoworks
Jan 17, 2003 10:19 PM
