ST sway bar installation?
u dont need pics, once u jack up the car u will see, for front take out the stock one and the st goes in same spot and same bolt points and everything, for the rear there should already be holes, stick it on and then look for the holes on the trailiing arms to attatch it to, theyre about as easy to install as an intake
the rear may need to be preloaded, but maybe not...everyone seems to have different experiences with mounting the rear st swaybars...but yes, there are factory mounting locations regardless of which model you have...
JDM_dreamer
Jan 8, 2007 08:17 PM
