oil squirters on h23
Old Apr 27, 2005 | 09:23 PM
myhatch98's Avatar
Default oil squirters on h23
are they necessary unlike the b series motors or will it be fine without it. It will be reving to 9000 rpms
Old Apr 27, 2005 | 09:45 PM
Innovation's Avatar
Default Re: oil squirters on h23 (myhatch98)
If you have cast pistons its good to run them. Squirters were put in place to cool the cast piston and aid in the lubrication of the wrist pin. If your running forged pistons theyre not really necessary.
Old Apr 27, 2005 | 10:03 PM
myhatch98's Avatar
Default Re: oil squirters on h23 (Innovation)
but i was told told that on stock sleeves i can only run cast pistons and that with the type s pistons they wont clear what can i do do u know
Old Apr 28, 2005 | 05:20 AM
PirateMcFred's Avatar
They will bolt in but the H23 crank will hit them. It is a bigger problem with the crank than the pistons. You will have to bend them a little to get them to clear the crank. It is trial and error. It has been done quite a few times but it is frustrating. So take your time and have patience.
Pirate
Old Apr 28, 2005 | 06:45 AM
Sam1am26's Avatar
Default Re: oil squirters on h23 (PirateMcFred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">You will have to bend them a little to get them to clear the crank. It is trial and error. It has been done quite a few times but it is frustrating. So take your time and have patience.
Pirate</TD></TR></TABLE>
Old Apr 28, 2005 | 03:43 PM
myhatch98's Avatar
Default Re: oil squirters on h23 (Sam1am26)
but is having them necessary or can i get away without having them how about the balancer shafts should i get rid of them or keep them let me know thats alot of weight they put on and i dunno if the car can run without it
REDLUDE4WS
Oct 29, 2012 04:44 PM
mightymaxgst
Jun 13, 2009 12:06 AM
crazykid
Jul 25, 2006 04:55 AM
ej1_lsvtec
18
Jul 16, 2006 03:11 PM
v-6 hatch
Mar 1, 2005 08:09 PM
