going to pull my engine tomorrow...want to know if steering will work without axles
Old Apr 27, 2005 | 08:44 PM
sparxx's Avatar
Default going to pull my engine tomorrow...want to know if steering will work without axles
want to know if I reconnect suspension will car roll and steer right
I think axles are required but am hoping someone can enlighten me
Old Apr 27, 2005 | 08:47 PM
EF Two.'s Avatar
Default Re: going to pull my engine tomorrow...want to know if steering will work without axles (sparxx)
LOL......Are you serious????????? But anyways yes the car will steer and roll...lol
Old Apr 27, 2005 | 08:48 PM
SiR Inspired ED7's Avatar
yup
Old Apr 27, 2005 | 08:53 PM
vtecn8ive's Avatar
Default Re: going to pull my engine tomorrow...want to know if steering will work without axles (88 Crx Si)
haha good stuff. your axles are your drivetrain. meaning they are inline with putting the power to the pavement.
Steering has to do with the front knuckles, lca, uca, and tie rod/steering rack
Axles attach transaxle to steering knuckle to make the wheels rotate
sparxx's Avatar
Default Re: going to pull my engine tomorrow...want to know if steering will work without axles (EF Two)
thanks..didn't know if the axles leveled the wheels in front..thanks again
Old Apr 28, 2005 | 03:09 PM
NCchris's Avatar
It will steer fine, but if you don't have the splined end of the axle through the knuckle with the nut on, you run the risk of separating and damaging your wheel bearings. The knuckle has two bearings pressed in and the axle and spindle nut holds everything in compression preventing the bearing from coming apart. I wouldn't roll it far.
HTH
chris
VIS250P
Feb 5, 2007 08:37 AM
Paul1985
10
Aug 15, 2006 11:42 AM
ice11honda
Aug 11, 2004 05:16 PM
89Si
May 21, 2003 04:42 PM
shortyz
Mar 29, 2003 03:36 PM
