Help!!!!! tail light problems.
Ok I have a 89' crx hf, and I noticed that the rear tail lights weren't working so I go to replace them and there were no bulbs. So i go to schucks to get all the rear lights I need when I was putting them in I noticed that the stop lights are constantly on. I've looked in the Chiltons book and have'nt been able to sovle the problem. I just got the car from some ricer, so please dont flame this
thank you for your help
i know there is a brake light switch under the dash that senses when the peddle is pushed.. if that thing is all muffed up, then that could be why they are always on. unfortunatly the name of the switch escapes me now, but im sure someone around here knows what it is called.
Check your Ground wire, maybe your not getting enough of it.
try getting the wire where they are placed on and sand it down a lil bit to help it get more ground or place the wire somewhere else
Thanks sani we just put a bolt threw the hole on the brake pedal arm to to keep the brake switch engaged. thanks agian for everyone's help marcus
redef90si
Aug 26, 2012 05:22 AM
thiendegigolo
Apr 29, 2011 10:45 AM
