what's WRONG with my FRIENDS type s TRANNY ? ? ?
here is our convo..he can't go on h-t because the admins where he goes to school blocked forums.
cwis37 [8:31 P.M.]: ok big problem driving the car today
I rodimus I [8:31 P.M.]: what happened
I rodimus I [8:31 P.M.]: needs new driver?
cwis37 [8:31 P.M.]: was driving out, shifting normal
cwis37 [8:31 P.M.]: no
cwis37 [8:31 P.M.]: then i got to 6th gear, wouldnt engage
cwis37 [8:31 P.M.]: like wouldnt even go into 6th
cwis37 [8:31 P.M.]: then i stoped,
cwis37 [8:31 P.M.]: wouldnt go into reverse
cwis37 [8:31 P.M.]: i was like ****
cwis37 [8:32 P.M.]: then i started again
cwis37 [8:32 P.M.]: was hard to get into 6th, but went in
cwis37 [8:32 P.M.]: then everything was fine
cwis37 [8:32 P.M.]: then now
I rodimus I [8:32 P.M.]: was the car cold
cwis37 [8:32 P.M.]: nah
cwis37 [8:32 P.M.]: but driving back, now it grinds going into 5
I rodimus I [8:33 P.M.]: everytime?
cwis37 [8:33 P.M.]: yeh
check the clutch master cylinder and see if it is full if not put in some dot3 brake fluid in that bad boy
also check for leaks below the clutch pedal if it is low. might have a clutch m/c leak
Modified by diewX3 at 10:51 PM 4/27/2005
well i just read another thread that there is a TSB out on the rsx??dont know what that maens but people are saying the tranny is griding left and right so if its under warranty they will service it..i dont know its at the top of this forum right now check it out....the title is should i go to the dealer?
