Anyway to fix the tach?
Old Feb 1, 2002 | 08:38 AM
B2FiNiTY's Avatar
Default Anyway to fix the tach?
Since the tach is off... is there anyway to fix it? I know I'm shooting in the dark here... Just wondering.
Old Feb 1, 2002 | 08:39 AM
OneThirtyEight's Avatar
Default Re: Anyway to fix the tach? (B2FiNiTY)
..wait until you hit the rev limiter, then you know how far its off
Old Feb 1, 2002 | 08:53 AM
yoshi234's Avatar
I shoot brides
yes, there is.
before I put on the yellow needles, w/ the help of robert and a OBD scan tool we were able to see the exact rpm.
1. remove stock needle
2. rev car to exactly 1500 rpm according to scan tool
3. pop tart in the needle
4. rev car to 3500 rpm according to tach and check scan tool for accuracy
*5. repeat 1~4 if necessary
yshi - whose vtec kicks in at exactly 5700 and hits rev limiter at exactly 8700 rpm now
Old Feb 1, 2002 | 09:07 AM
CPR's Avatar
CPR
Default Re: Anyway to fix the tach? (yoshi234)
yes, there is.
Simple yet ingenious. McGyver in the hiz house.
Old Feb 1, 2002 | 10:00 AM
Blue Liquid's Avatar
New User
Default Re: Anyway to fix the tach? (CPR)
Why doesn't your rev limiter kick in at 8500?
Old Feb 1, 2002 | 10:03 AM
B2FiNiTY's Avatar
Default Re: Anyway to fix the tach? (Yellow R #01-0468)
Should be 8700. Dang thats ingenious... I'll try that out *IF* I get a spoon cluster.
Old Feb 1, 2002 | 10:08 AM
yoshi234's Avatar
I shoot brides
this method works to calibrate the speedo also
yoshi - whose gas still reads low constantly
Old Feb 1, 2002 | 10:12 AM
New User
For years i was under the impression that it comes on at 8500. It even says that on my brochure. Why should it be 8700?
Old Feb 1, 2002 | 10:14 AM
Cosworth's Avatar
Be very careful... there is a good chance of bending or breaking the needle. Then, you're fugged.
Old Feb 1, 2002 | 10:24 AM
B2FiNiTY's Avatar
Default Re: Anyway to fix the tach? (Cosworth)
Anyone know where I can borrow a OBD scan tool? The only place I know of is go back to my old high school auto class and use my teachers.
Old Feb 1, 2002 | 01:41 PM
STOLEN - ITR 98-0652's Avatar
Can I use toaster strudle?
All kidding aside... y'all need to hook me up with that technique!
V - who hasn't seen another ITR since...
Old Feb 1, 2002 | 01:47 PM
yoshi234's Avatar
I shoot brides
Default Re: Anyway to fix the tach? (ITR 98-0652)
is your tach our of whack?
yshi - who think maybe we need to set up a calibrate da stock guages day
Old May 24, 2002 | 02:47 PM
uNF$@#!'s Avatar
needle is made of plastic
matix
Jul 10, 2006 06:25 PM
jaidedeye
Jun 29, 2005 04:24 AM
Padawan
Jun 30, 2003 04:25 PM
PiYoImuT
Jun 29, 2001 10:57 AM
