ZC crank - is there any interchangable
I have a ZC motor that spun a bearing, just wondering what cranks are interchangable. I've heard that 88-89 tegs are interchangable, but I'm not sure. Also, D16A6 but has 2 different "snout" sizes. Just trying to make sure which one I should get. Thanks.
for your zc any d-series will work . but the best set-up is a crank and harmonic balancer out of a 1992 civic ex. You want to get the one with the 24mm snout, also you will need to get the alt pulley with that do to its a 4 rib set-up. Its a drop in afair besides getting the proper bearing clearance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZC1.8crx »</TD></TR><TR><TD CLASS="quote">for your zc any d-series will work . but the best set-up is a crank and harmonic balancer out of a 1992 civic ex. You want to get the one with the 24mm snout, also you will need to get the alt pulley with that do to its a 4 rib set-up. Its a drop in afair besides getting the proper bearing clearance. </TD></TR></TABLE>What makes the Z6 crank in the first year of production so much better then all the rest?
um i think you mean 2001+ civic cranks. The 2000 civic is a 1.6L crank!
Henry ill pick up the z6 crank tommorow and balancer. Hopefully they wont charge for both!
HAHA ill say its not able to come off!
ROTFL...... I love how everyone screws them at UWI!!!
better check your timing gear for the crank to make sure it will fit the 24mm Z6 snout - your ZC is probably 22mm, in which case you need 86-87 D16A1 or 88 (some were 22mm and some were 24mm) D16A6 - you must use your ZC crank gear
91civichatch2571
Oct 20, 2004 09:04 PM
