b16a rev
actually the pr3 ecu has a rev limit at 7 wen the motor is cold. if it still does it even after letting it get hot, then you could have the wrong thermostat. my friend had this same problem with his ZC swap. check into it. your ecu probably still thinks the car is cold even when it is warm.
