what to expect from a good paint job
Old Apr 27, 2005 | 06:55 PM
pgpunkguy's Avatar
Default what to expect from a good paint job
so i'm looking into having some body parts repainted factory color.
is there something i should be looking for to get a good paint job?
like # of clear coats or type of paint used?
Old Apr 28, 2005 | 05:36 AM
pgpunkguy's Avatar
Default Re: what to expect from a good paint job (pgpunkguy)
anyone?
Old Apr 28, 2005 | 05:50 AM
ChaseIntegra's Avatar
Just make sure they match it, that's the biggest thing. They need to get a paint sample from your car so they can color match it to whatever is getting painted. They will handle the rest from there.
Old Apr 28, 2005 | 08:38 AM
pgpunkguy's Avatar
Default Re: what to expect from a good paint job (ChaseIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChaseIntegra &raquo;</TD></TR><TR><TD CLASS="quote">Just make sure they match it, that's the biggest thing. They need to get a paint sample from your car so they can color match it to whatever is getting painted. They will handle the rest from there.</TD></TR></TABLE>
well i was thinking they normally paint the factory color and then tint to match the rest of the car (since the rest of the car paint fades a little)
but is there anything i should be looking for as far as paint type? or # of clear coats?
Old Apr 28, 2005 | 11:55 AM
pgpunkguy's Avatar
anyone know?
Old Apr 28, 2005 | 12:36 PM
1995chardx's Avatar
i think the prepping is the most important thing...even with however coats of clear or paint, if the prepping is wack then the paint job will be wack
Old Apr 28, 2005 | 02:01 PM
pgpunkguy's Avatar
Default Re: what to expect from a good paint job (1995chardx)
what exactly do you mean by "prepping" like body filler and sanding? or paint primer?
Old Apr 28, 2005 | 02:03 PM
Rtistik.'s Avatar
i believe he means sanding and primer..make sure you check for scratches or bubbles when you get it back
Old Apr 28, 2005 | 02:07 PM
pgpunkguy's Avatar
Default Re: what to expect from a good paint job (Rtistik.)
so basically i should make sure the surfaces are nice and smooth before i send to paint... or have them do the filling/sanding...
jadeydrag0117
Paint and Body
Nov 8, 2012 12:21 AM
Tinoo
Paint and Body
Oct 11, 2010 07:56 PM
crxnightrider
Paint and Body
Jan 12, 2008 07:27 PM
Kirk@SyndromeAuto
Paint and Body
Nov 12, 2007 08:53 PM
O16581724 5 2 5
Oct 12, 2005 11:22 PM
