B16 Swap Complete but Car Idles Very low (200rpms) and wont go past (2,500rpms)
Old Apr 27, 2005 | 05:30 PM
TiMMaYBoYiE's Avatar
Default B16 Swap Complete but Car Idles Very low (200rpms) and wont go past (2,500rpms)
I just swaped a b16 into my 89 CRX-DX. I converted the Dual Point Injection to Multi-Point and connceted the all the VTEC components, crank sensor and the O2#2 sensor. The car started but Idles very low. Its throwing the Crank Sensor code (4) and TPS (7) and IACV code (14). Anythoughts as to check if the crank sensor is in good operation and the TPS?
ALSO:
Does anyone have ECU wiring and or Vacuum line diagrams from a reliable source?
Old Apr 27, 2005 | 05:51 PM
NikoZai's Avatar
Default Re: B16 Swap Complete but Car Idles Very low (TiMMaYBoYiE)
checkout http://www.droppedcrxsi.com
Did you swap the TPS wires?
Check this MPFI swap guide, it mentions what others do not.
http://effinmotorworks.com/Effin_MPFI_swap.htm
Old Apr 27, 2005 | 06:14 PM
Default Re: B16 Swap Complete but Car Idles Very low (NikoZai)
Yes the TPS wires were swapped! ANd are those ECU Diagrams for a pr3 ECU?
Flyingchopstick
Jul 14, 2005 11:24 AM
crx90rcr
May 1, 2005 11:23 AM
TiMMaYBoYiE
17
Apr 30, 2005 04:26 AM
xvracing
11
Oct 27, 2003 05:21 AM
Danbu$
14
Apr 10, 2003 10:27 AM
