90'civic hatch help please
Old Apr 27, 2005 | 05:13 PM
baked_beanz's Avatar
Default 90'civic hatch help please
ok, it started today. i walked out to start my car. but when i turned the key to start. i got nothing. the lights turn on and the radio works but it doesnt turn over to start. i just get a small click. then me and a friend of mine decided to pop the clutch rolling down my hill. and the car started. i drove it around the block its running ok. then i park it turn the car off. and try and start it again and the starter work like twice and then stop again. one of my friends says its the starter and another thinks its the alternator. if anyone know what could be wrong please let me know asap. this is my only car and i need trasportation. thanks in advance
Old Apr 27, 2005 | 05:15 PM
hatchling37's Avatar
Default Re: 90'civic hatch help please (baked_beanz)
Are your lights dim when you turn the key to the on position? Did the starter sound really labored trying to turn over? Did you check your fuses and relays?
Old Apr 27, 2005 | 05:18 PM
it didnt even start to turn over. but after i poped the clutch and i started it,it sounded kind of weak.what fuses do i check and what relays?? im new o honda's
Old Apr 27, 2005 | 05:19 PM
if this helps any. the starter wouldnt even turn on when i tryed jumping it with another car
Old Apr 27, 2005 | 05:40 PM
deserthonda's Avatar
if it clicks it is either a bad starter, a bad battery or battery cables poor connection ,,,,have someone try to start car i know you said nothing happens but while they are starting get a big screwdriver and tap on the starter if it engages you got a bad starter
Zack...
35
Aug 26, 2015 05:38 PM
Frank1515
Jun 24, 2015 10:47 AM
preludedriva
Nov 16, 2006 12:18 AM
hondachris1994
Aug 3, 2006 01:05 PM
skata89
Jan 14, 2006 10:08 AM
