xenon light question
Old Apr 27, 2005 | 02:46 PM
vc's Avatar
vc
Modified by vc at 9:36 PM 3/5/2006
Old Apr 27, 2005 | 07:12 PM
Nick H's Avatar
New User
Default Re: xenon light question (sh0rti)
low beam are 9006 and high beam are 9005...i'm not real sure what the h11 and h10 are, so i can't help you there...
Old Apr 27, 2005 | 07:29 PM
hometheaterman's Avatar
Default Re: xenon light question (Nick H)
yup I don't know about what h11 and h10 are but 9006's are low beams and 9005's are high beams.
Old Apr 27, 2005 | 09:47 PM
What the heck size is H10 what uses it? I have never heard of it. Those arnt Nokya bulbs in that pic are they? All the ones I have seen have been tinted blue not clear like those.
Old Apr 27, 2005 | 11:17 PM
philadd's Avatar
From my understanding, H11s and H10s are new bulbs, one of which I think is for a VW's (forgot which car) foglights.
The fact that they are H10s or H11s has nothing to do with color...
Old Apr 28, 2005 | 06:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sh0rti &raquo;</TD></TR><TR><TD CLASS="quote">you said you never heard of H10.. so that means your blue bulbs.. aren't these white bulbs.. and yes they are nokya.. "arctic white" ... please read x) (as well as search)</TD></TR></TABLE>I don't have Nokya blue bulbs just the ones I had seen at Circuit City were blue coated Artic Whites but I have never heard of the H10 size.
Old Apr 29, 2005 | 07:29 AM
Schmitey's Avatar
for you xenon bulb users, what is your opinion on their projection?
I've heard some debate that you can see further but they don't light up the road as well. What's do you think and is it worth the cost? I don't care about aftermarket headlights and making heads turn, I just want the best bulb.
Old Apr 29, 2005 | 07:42 AM
hypnosisracing's Avatar
Default Re: xenon light question (Schmitey)
^^^ Save for HID's. Thats all i can say when people want to spend cash on improving visibility with new headlights...the best "bulbs" (halogen) dont even compare, theres been some comparisons of the Silver Star bulbs in certain projectors being rather impressive, but i have to say...i will never own a car without HID's.
Old Apr 29, 2005 | 07:47 AM
accordselux's Avatar
Me Gusta History
Default Re: xenon light question (hypnosisracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypnosisracing &raquo;</TD></TR><TR><TD CLASS="quote">^^^ Save for HID's. Thats all i can say when people want to spend cash on improving visibility with new headlights...the best "bulbs" (halogen) dont even compare, theres been some comparisons of the Silver Star bulbs in certain projectors being rather impressive, but i have to say...i will never own a car without HID's.</TD></TR></TABLE>
HIDs are the best upgrade, i've gone through 4 different types of bulbs before I went HID. 4300-5300k is the best range. Some stock housings are good (if the bulb is shielded) but i'd make sure to invest in a good set of OEM projectors and do a total retrofit so you dont get glare and blind oncoming traffic.
Old Apr 29, 2005 | 10:00 AM
Schmitey's Avatar
Default Re: xenon light question (accordselux)
Can I get an OEM replacement for my 96 EX that has the little reflector for xenon? Also I know I've read some stuff on xenon bulbs drawing a lot of power and doing screwy stuff with your electronics.
Old Apr 29, 2005 | 10:52 AM
What about a reflector? You talking about Xenon as in halogen bulbs you would buy from best buy or somewhere like that that say Xenon or are you talking about real HID Xenon? Real HID's should be fine for your wiring since you have to rewire them. Regular Xenon bulbs should be ok unless you go with higher wattage ones then you either need to get a wiring harness for high wattage bulbs or the are very likely to melt your wiring. You can get reflectors from BMW's or Nissans or whatever has HID's and retro fit them into your housings if thats what you are talking about.
Old Apr 29, 2005 | 01:55 PM
sumptimwong's Avatar
Default Re: xenon light question (hometheaterman)
so many misconceptions out there.... seems like only accordselux knows anything about hid
get on google, do some basic searches about how HIDs work. "xenon" is a widely used misnomer there days. some halogen bulb manufacturer "inject" the bulb with xenon gas, which doesnt do jack squat because its the filament thats doing the lighting, not the xenon gas. in HID (as we SHOULD call it), there is no filament, and its actaully the electron emissions from the xenon atoms that are creating the light. temperature range that will create the most lumens is 4100-4200, though occassionally youll see OE HID go up to 5300. the higher you go, the more blue the light will become, and the more glare you will produce, and it also tends to fatigue your eyes more quickly.
IMO, HID in stock reflector housings are a waste of time and money. if youre going to planning to spend the 150-200 for a HID conversion, wait until you have afew hundred extra to do a complete projector housing retrofit into your headlight housing. the s2000 projectors are among the best out there, along with lexus gs. dont buy those cheap aftermarket projectors, theyre crap. you want to look for clean cutoff lines, in order to minimize glare.
and no, xenons dont draw more juice, they draw LESS. a 35w HID bulb will put out more lumens than any 65w halogen out there, hands down.
bottom line: make sure u do some good searches before you buy ANYTHING.
btw, in case any of you want more details, heres a good site that explains most of what i mentioned above: http://www.intellexual.net/hid.html
Old Apr 29, 2005 | 03:54 PM
businessmanph's Avatar
what would the exact steps be to retro fit hids into a 97 accord?
how much would it cost just go get a stock set of hids (no retro fitting)?
Old Apr 29, 2005 | 10:48 PM
Nick H's Avatar
New User
Default Re: xenon light question (businessmanph)
depending on the kit, anywhere from 250-600...you can get aftermarket kits that you don't need to retrofit, however i personally retrofitted projectors in my oem housings and hids...much better output than oem reflectors i must say...
Old May 1, 2005 | 11:29 AM
Schmitey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H &raquo;</TD></TR><TR><TD CLASS="quote">however i personally retrofitted projectors in my oem housings and hids...much better output than oem reflectors i must say...</TD></TR></TABLE>
how'd you manage to do that? And how much are we talking for the bulbs alone?
Old May 3, 2005 | 12:53 PM
hey schmitey.. the retrofitting is a pretty involved process that involves removing the housing and the housing cover, drilling some big holes to fit teh projector lenses on.. and the such. i found a link on google a while ago that showed how to do it on a different car.. ill link it back if i can find it again.
as for cost.. the bulbs alone (plus the ballast, which u need) should cost 150-200, depending on which brand u get. i recommend phillips for the bulbs, and hella for ballasts. theres another good name for bulbs, i cant remember off the top of my head.
shorti, no offense intended. i wasnt directing the general knowledge at you, sorry if seemed to insult your intelligence. i wrote a lot bc i wanted to touch upon everything that seemed unclear in the earlier posts. i wanted to put out the general info for others who stumble upon the thread.
Old May 3, 2005 | 02:25 PM
Nick H's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schmitey &raquo;</TD></TR><TR><TD CLASS="quote">
how'd you manage to do that? And how much are we talking for the bulbs alone?</TD></TR></TABLE>
there's another post on here that i posted pictures of my retrofitted headlights...the link is https://honda-tech.com/zerothread?id=1231052
scroll down to see the pics...
Old May 3, 2005 | 02:35 PM
icewave's Avatar
I have a 2002 accord and the H11 bulbs are for my fog lights
Old May 3, 2005 | 03:33 PM
Me Gusta History
Default Re: xenon light question (icewave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by icewave &raquo;</TD></TR><TR><TD CLASS="quote">I have a 2002 accord and the H11 bulbs are for my fog lights </TD></TR></TABLE>
98-02 accords use 9005's for the highs...
Old May 4, 2005 | 01:37 PM
icewave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordselux &raquo;</TD></TR><TR><TD CLASS="quote">
98-02 accords use 9005's for the highs...</TD></TR></TABLE>[QUOTE=accordselux]
foglights...
DTvn
Lighting
Apr 29, 2013 04:03 PM
hometheaterman
Apr 5, 2005 01:16 PM
integrakid
Mar 25, 2005 03:45 PM
HondaTypeS
Aug 30, 2002 01:59 AM
Duck Sauce
Dec 12, 2001 01:26 PM
