Need help with speedometer!
Old Apr 27, 2005 | 02:18 PM
EJ8tunerman's Avatar
Default Need help with speedometer!
The deal- 1998 Civic EX. Speedometer is at 0 while car is off. Turn key to "ON" position and speedometer jumps to around 20ish. Start car and sometimes it drops to zero and works regularly, but sometimes it just stays, and then other times it will just fluctuate from 20-22-20 and so on. ALso I might add that sometimes when I'm driving down the road the speedometer will jump from 20 then start working normally, but will proceed to stop either when i turn the car off or on its own while driving still. I don't see how it can be the gauge cluster, and I dont see how it can be the VSS, reason being im not getting a check engine light, and VTEC is engaging normally in the low 5ks.
Anyone got a clue on what the problem could be or have had a similar situation?
Old Apr 27, 2005 | 08:01 PM
Default Re: Need help with speedometer! (cb7tunerman)
Any help? im stumped.
Old Apr 27, 2005 | 08:04 PM
eg6_rick's Avatar
i dink its your wiring and plugs by the VSS, check those...they might be dirty or cracked.
Old Apr 27, 2005 | 08:58 PM
Default Re: Need help with speedometer! (eg6_rick)
Thought so too,.That was the first thing i thought of, until i unplugged the VSS and blew all the dirt out of the connector and the vss. Problem still consisted.
Old Apr 27, 2005 | 09:15 PM
EJ8VTEC's Avatar
Mr. Indecisive
check your grounds
Old Apr 27, 2005 | 09:49 PM
92b18cx's Avatar
try and swap a vss from a friend's car, the same thing was happening to me and I swapped one from an old engine I had lying around, and it worked no problem.
jumpin4abeat
19
Apr 15, 2017 01:02 AM
surfer1735
Jun 20, 2008 11:57 PM
Jodster
14
Nov 9, 2006 07:42 AM
ts94acc
Oct 13, 2005 09:55 PM
red-eg6
Jul 5, 2005 08:26 PM
