ARP rod Bolts Necessary?
Old Apr 27, 2005 | 01:29 PM
Spyderman4g63's Avatar
Default ARP rod Bolts Necessary?
I have a friends car at my house that has recently had a LS/VTEC Conversion done by Honda Fiend, and after only a month or so the engine has developed a loud knock(rod knock) btw 2K and up. Upon tearing the motor apart I noticed that the rod bolts were stock. Is it necessary to use ARP rod bolts with this application. Could this be the cause of our problem? It is a b18B with an OBD II B16a2 head. Please Help!
Old Apr 27, 2005 | 01:43 PM
drdisco69's Avatar
Default Re: ARP rod Bolts Necessary? (Spyderman4g63)
Another one bites the dust... Rod bolts aren't required, but only if you're going to stock rev limit. Chances are it was going higher, hence the problem. ARP bolts will let it go as high as you need, the stock ones are pretty crummy.
Old Apr 27, 2005 | 02:15 PM
clint g's Avatar
Default Re: ARP rod Bolts Necessary? (drdisco69)
I agree and while you had it apart fresh bearings might help the cause
Old Apr 27, 2005 | 03:30 PM
Grand's Avatar
not neccesary but probably the cheapest insurance youl ever get
Old Apr 27, 2005 | 03:59 PM
DonF's Avatar
Default Re: (LG_R32)
No reason you cannot rev a 15-20 year old motor to 9000 RPM. Bad carma.
Old Apr 27, 2005 | 05:37 PM
HondaTechIsTheGay's Avatar
Get them.. Plain and simple.
Old Apr 28, 2005 | 06:41 AM
Well the car is a 98 DX with no Tach. I told this fool to get one, but his engine died first. Thanks for all the help..
2ndchirp
Jun 20, 2024 01:15 PM
Longbow
Aug 23, 2010 06:13 PM
418whpturboD
Jun 25, 2009 11:40 AM
turbolshatch
Jan 21, 2006 09:55 AM
stevescivic
Jan 27, 2005 10:18 PM
