Whistle noise coming from passenger side engine bay ??
While I am having my car fixed I want to have them take a look at this whistle noise come from the passenger side of the engine bay at 2000 rpm and up usually. Im assuming its a bearing but do not know what.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeFFFFFFFrey91 »</TD></TR><TR><TD CLASS="quote">it sounds like a bearing </TD></TR></TABLE>
Does the noise continue when you're not on the throttle? Say, at 50 mph and you let off the gas?
If you think it sounds like a bearing, does the noise increase when making a left-hand turn?
Does the noise get louder (higher pitch) when you accelerate and does it eventually taper off? I had this problem with my baby, but never got around to it before letting her go.
What type of intake system are you running ? Stock air box don`t whistle !
And if its a bearing noise coming from the passenger side , the noise will be made at a certian speed , i.e while the car is moving . Do the whistle noise come even if your car is not moving ? when your car is free and touch the gas peddal and you hear the noise it will be the intake .
With my AEM cold air intake system it whistle alot
When I was running the stock box , when I mean stock all stock , it didn`t whistle ...
I had to take off the upper lid so I can hear the engine scream more because it was so quite
No I am pretty positive it is not the intake, I had somebody look at it and they said it might be a pilot bearing ?? I tried searching but absolutely found nothing. If I take out the resonator will it help me decide whether or not its the intake ??
When you say you take out the resonator I asume that you have a stock air box. When exactly the noise starts , is it when your car is at a certain speed ? or it`s when the car is sitting and you are reving the engine ?
mine whistles depending on throttle position. speed does not matter.
AEM CAI whistles just the same as the stock intake for me
.MilanoRex
13
Sep 15, 2003 06:20 PM
