2001 honda accord motor swap
Old Apr 27, 2005 | 01:07 PM
new2tuning's Avatar
Default 2001 honda accord motor swap
what motor swap would be good to put in a stock honda accord? I was thinking h22 prelude motor, but if you have an idea please let me know.
Old Apr 27, 2005 | 02:21 PM
trinitymotors's Avatar
Default Re: 2001 honda accord motor swap (new2tuning)
I did an H22 in my gen 6 and it is incredible....you can use the factory F23 gearing, though it is geared incredibly long. The motor mount on the timing belt side doesn't fit exactly, but the others work perfect. I did the AEM stand alone, so had to make the wiring harness. As far as I know (which isn't much) nobody makes a conversion harness yet, so a lot of wiring will need to be done.
you can use your F23 based a/c compressor, alternator and power steering pump, so basically all you need is a stripped down H22. However, I would strongly suggest doing the auto to manual timing belt tensioner when you do this swap
Beau Gotti
Jan 6, 2019 09:07 AM
stevieh6
Jan 26, 2011 09:12 AM
keraann
Oct 17, 2007 05:42 PM
jakeiscool
May 15, 2005 02:39 PM
PHiZ
Aug 11, 2004 06:57 AM
