96 accord swapped with a 92 h22 -- How do I check the CEL ?
Old Apr 27, 2005 | 10:51 AM
Atheist's Avatar
Default 96 accord swapped with a 92 h22 -- How do I check the CEL ?
There doesn't apear to be a service connector like there is on civics and integra's, and I tried jumping it in the way that I saw (bottom right pin and 4 up from the bottom on the left column) but I couldn't get it to tell me.
Stock h22a obd1 ecu. Car is cranking, fueling, but not sparking. I need to figure out what the CEL is for!
Old Apr 27, 2005 | 12:36 PM
Atheist's Avatar
Got it running, still would like to check the code to make sure I am only throwing TPS (cracked)
Old Apr 27, 2005 | 01:42 PM
xbn83's Avatar
Default Re: 96 accord swapped with a 92 h22 -- How do I check the CEL ? (Atheist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Atheist &raquo;</TD></TR><TR><TD CLASS="quote">There doesn't apear to be a service connector like there is on civics and integra's, and I tried jumping it in the way that I saw (bottom right pin and 4 up from the bottom on the left column) but I couldn't get it to tell me.
Stock h22a obd1 ecu. Car is cranking, fueling, but not sparking. I need to figure out what the CEL is for!</TD></TR></TABLE>
Service connector on '96 accord is located behind the glove box.
Old Apr 27, 2005 | 02:51 PM
Atheist's Avatar
Default Re: 96 accord swapped with a 92 h22 -- How do I check the CEL ? (xbn83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xbn83 &raquo;</TD></TR><TR><TD CLASS="quote">Service connector on '96 accord is located behind the glove box.</TD></TR></TABLE>
The glove box isn't in his car, and I still don't see it...
Maybe I'm blind?
aznsins88
Jun 4, 2006 07:17 PM
Neldawg
Nov 16, 2003 04:36 PM
92hybridAccord
Aug 20, 2003 12:28 PM
kasper
Apr 2, 2003 04:42 AM
jaosnwallace
Feb 28, 2003 10:48 AM
