Right turn signal has ADD
Well my car used to signal fine, I changed my signal bulbs (corner lense) and the left one signals fine, but the right side flashes twice as fast. Now it wont even signal, only my rear right side signals. The bulb still lights up when lights/parking lights are on but no signal....wtf.
Could it be a bad fuse or some ****, or maybe the wiring got screwed up? But why is this happening from just changing a bulb, I did not mess with any fuses or wiring
car is a 93 dx sedan (eg8)
you need to look at the bulb you bought it might be a single filament bulb. corner lamps uses dual filament one for signal and another that's on when you turn switch. put your left side bulb on the right one and see if it will work fine. If it does then your bulb needs changing but if it stays the same check wiring
Iloveyourhonda92
May 10, 2010 09:29 PM
civiccoupe94
Oct 14, 2007 05:27 AM
