Will stock injectors be OK???
Old Apr 27, 2005 | 09:50 AM
93dx--hatch's Avatar
Default Will stock injectors be OK???
all stock 01 ITR head, IM, TB, cams
gsr block w/ b16 81.5mm pistons,
3 layer gasket
aem cold air
dc 4-2-1 header
2.25in exhaust
Would I be able to get away with an all stock full system on this. I have a p28 w/ uberdata, I was just going to run it on a stock JDM ITR base map.
Old Apr 27, 2005 | 10:22 AM
chameleon's Avatar
Default Re: Will stock injectors be OK??? (93dx--hatch)
if you did a search you would see that several people are pushing past 200whp with stock injectors and stage 2 cams so then its easy to say you can make the assumtion will be fine as long as you get a wideband and tune properly.
Old Apr 27, 2005 | 11:11 AM
X2BOARD's Avatar
uummm...yeah... what he said....^^^
You'll have a good bit of headroom even with the stockers.
GagnarTheUnruly
Engine Management and Tuning
Jun 29, 2011 08:07 PM
Bay Area Baller
Dec 11, 2006 10:03 PM
SkoundrelUSA
14
Jul 19, 2006 05:34 PM
an2ny888
Jul 7, 2006 10:50 AM
Bense
Jun 22, 2004 10:03 AM
