What's the problem?
Old Apr 27, 2005 | 09:40 AM
sqad_7's Avatar
Default What's the problem?
I've got a friend who has a 96' accord with a h22 swap not the type s. The person he bought the car from had a stock SI ecu in, he switched it out with a chipped p28 that had a swith for the stock settings and for chipped settings. Soon as he started up the the motor was flooded we let it sit, switched it back to stock settings car ran fine and started up. Would the problem be the fact that he's using an ecu thats running a fuel map for a 1.6/1.8?
Old Apr 27, 2005 | 05:07 PM
sqad_7's Avatar
Default Re: What's the problem? (sqad_7)
maybe i posted in the wrong forum?
Old Apr 27, 2005 | 05:17 PM
YeuEmMaiMai's Avatar
fuel map is wrong or ECU is keeping the injectors open too long when you set it to the performance option. what engine was the performance option for?
Old Apr 27, 2005 | 10:27 PM
Nick H's Avatar
New User
Default Re: What's the problem? (YeuEmMaiMai)
the ecu settings with the chip is obviously running way too rich...what chip did you use? was it something you tuned yourself or was it purchased somewhere...if you didn't do it yourself, then you may want to have it tuned by a reputable shop who is familiar with uberdata tunes...
Old Apr 28, 2005 | 06:37 PM
sqad_7's Avatar
Default Re: What's the problem? (Nick H)
He bought the ecu from a guy who chips them himself, he had originally chipped it for 1.6/1.8 motors. I figured the fuel maps would be completely diff. He bought a fields vtec controller would that be a good idea? or should he just get a prelude ecu?
Modified by sqad_7 at 7:45 PM 5/4/2005
killerCB7
Jan 29, 2010 01:42 AM
jdmdikk
22
Jun 30, 2009 06:04 PM
msinsky14
Jan 31, 2009 11:59 AM
Mingo
10
Sep 12, 2008 12:07 PM
OMG B16
Aug 23, 2005 11:02 PM
