Painting Valve Cover_ PCV valve question
Old Apr 27, 2005 | 08:23 AM
mwieczorek43's Avatar
Default Painting Valve Cover_ PCV valve question
Quick question.
I am ready to repaint my valve-cover (oem wrinkle black).
The engine that I have is an OBDII b18b1. Which has a PCV-valve comming out of the middle of the cover.
I found a OBDI b18b valve cover laying around in my garage which I'd like to use while I'm painting my cover. These dont have the PCV-valve on the cover.
Two questions:
1) Is it a bad idea to run without a pcv-valve for... one day tops. Hopefully I wont need to drive at all, but I am always on-call, and may need to drive.
2) Are there any suprise differences in these two covers. Upon examining them, they look good; but I wanted to get another opinion from you guys before I start taking sh*t apart.
Old Apr 27, 2005 | 09:38 AM
Bond's Avatar
Default Re: Painting Valve Cover_ PCV valve question (mwieczorek43)
The PCV just takes blow off gases and puts it back in the intale manifold to be burnt and exited out the exhuast. I wouldn't recommend it because stuff can get in there.
Old Apr 27, 2005 | 01:12 PM
Default Re: Painting Valve Cover_ PCV valve question (Bond)
If I pulled it, I would temporarily plug the line so nothing could be sucked in.
Is this a bad idea to do for a day.
anyone else?
Old Apr 27, 2005 | 09:57 PM
Bond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mwieczorek43 &raquo;</TD></TR><TR><TD CLASS="quote">If I pulled it, I would temporarily plug the line so nothing could be sucked in.
anyone else?</TD></TR></TABLE>
Your idle will be pretty low when you do this and tends to accelerate like a slush box. There is prolly a lot of people that don't take care of there cars and do regular tune ups (sounds like my sisters EG. They are most likely running with a bad pcv valve so it would prolly be o.k. for a day.
eksessiv
Welding / Fabrication
Feb 15, 2011 07:27 PM
AccordSleeperZzZ
Feb 24, 2008 08:37 PM
riceburnerryan
17
Dec 30, 2005 09:23 AM
jdmcivicferio
Mar 17, 2003 01:59 PM
