b20z2 rod bearings
Old Apr 27, 2005 | 08:10 AM
aldong's Avatar
Default b20z2 rod bearings
i pulled apart my block that had a bent rod and i found when i was putting it back together that on this block there are like 4 green bearings and 4 brown.
i had the paper to check what kind u need but dont understand really and confused help me ,
1st what 2 bearings do i use ,second, 3rd , and 4th
if anyone can help me with this and make me like a order they go in,or any info thanks
Old Apr 27, 2005 | 10:29 PM
CRXDrew's Avatar
umm... ok.. i'm trying to understand this...
u should have a manual to explain which color code bearing is used with each numbered rod/crank journal.
Aside from that I can't help you much.
Quetzolcotl
Feb 17, 2017 02:50 AM
CPreston
Feb 17, 2011 10:06 AM
desmone
Mar 18, 2007 04:39 PM
hatchedzex
Oct 13, 2004 03:01 PM
SkRiBLaH
Jul 28, 2004 10:24 AM
