93 idle problem
Old Apr 27, 2005 | 07:08 AM
badkent's Avatar
Default 93 idle problem
Hey guys, have a question, i have a 93 accord LX and lateley i've been driving on the freeway at about 70-80 and intermittently my rpm's fluctuate from 3k to 2k and back to 3k and stays and then it does it again. Now it only does it once in a while. Not to long ago i had the same problem and a month later my ignition module gave out. Any suggestions on this?? Is this related to the ignition module? Thanx.
Old Apr 27, 2005 | 08:31 AM
Filthy Focker!'s Avatar
Default Re: 93 idle problem (badkent)
Are you saying you got your foot on the gas and the rpms will jump? If so, don't drive your car to far from home. Might be a slipping clutch.
fs
Old Apr 27, 2005 | 08:51 AM
Legacy Accord's Avatar
Is your vehicle a Automation or Manual ?, I had the same problem with my automatic and some how it had to do with the Intake manifold
Old Apr 27, 2005 | 10:35 AM
badkent's Avatar
Default Re: (Legacy Accord)
its an automatic, and it only happens once in a bluemoon, my foot is on the gas, but its not the clutch slipping because i have no problem accelarating i pick up speed as it should its just when im at high rpm bout 3k or 3.5k it fluctuates 2-4 times and then it stops....
i thought it had to do with the ignition module since it did this about 3 months back and 2 weeks later it gave out. Took it in and turned out to be ignition module. Anyone have this problem???
PhilMac
Sep 11, 2007 07:30 AM
PRoJecTSLeePaLoT
Jul 31, 2005 07:39 AM
chochocho
Jul 27, 2004 01:52 PM
Ch33se
Feb 2, 2002 08:39 AM
