how do you remove side mouldings with 92 accord?
how do you remove side mouldings with 92 accord? I removed a nut inside the door side but the molding woudl not budge -is there another fastner I need to remove before sliding molding out??? do I slide it out? or pop it out?
Yes the one nut that is at the end of the molding, and then there should be some clips that are holding the rest of it on. The hard part about taking them off is getting it out w/o bending it. There are long thing strips of metal that are inside of the side molding and if you bend it too much, it will never be straight or look the same again. It can also leave a crease in the molding. Try using a flat-head screw driver to pry the clips out. Just be careful with the molding itself. Start where you removed the first screw and work your way down the rest of the molding.
Good luck!
Good luck!
JDM_DC4_Fanatic
Aug 12, 2007 01:45 PM
ttvegas2002
Aug 25, 2005 06:54 AM
civiceg_92
Dec 31, 2004 02:41 PM
