msd blowing fuses
Old Apr 27, 2005 | 04:40 AM
slow91crx's Avatar
Default msd blowing fuses
one of my 50 amp under hood fuses blew last night . i figured it was just my msd pulling too much current so i put in a 60. it blew again goin down the road after about 2 minutes. anyone had this problem. im gonna take the box off today and see if i can get it to stop blowin fuses.
Old Apr 27, 2005 | 06:30 AM
dr_latino999's Avatar
Default Re: msd blowing fuses (slow91crx)
You are drawing too much current through the circuit so either you will need a dedicated circuit or check all of your wiring to make sure it isn't grounding out.
Old Apr 27, 2005 | 06:53 AM
slow91crx's Avatar
Default Re: msd blowing fuses (dr_latino999)
the first time i blew the 50 amp, i replaced with a 60 amp to compensate for the extra current. well that time it lasted about 5 minuted and blew going down the road and a tiny puff of smoke came from under my dash. my msd is wired up correctly, if it wasnt it would not even start. i don't really see how that fuse has anything to do with my ignition . could it be a main relay? some guy said that was his problem wen his fuse kept blowing. maybe the relay just decided to kick the bucket?
Civic Racer X 7
11
Sep 13, 2014 12:59 PM
aztigen_eh2
Feb 5, 2008 10:53 PM
end005
Dec 4, 2007 06:00 AM
ToiletFetusSushi
Sep 27, 2004 09:07 PM
