simple question about oil
Old Apr 27, 2005 | 03:12 AM
kasso's Avatar
Default simple question about oil
if you have a tremendous amount of oil in the car (more than double the two dots), will the car eventually have problems starting? i thought it was the ignition so i put in the msd that was sitting around the house, and on cold starts, it always takes a while to start up. and white smoke is coming out of the exhaust.
btw. this is for 95 integra ls/v
Old Apr 27, 2005 | 05:21 AM
kasso's Avatar
any help would be appreciated
Old Apr 27, 2005 | 05:32 AM
Chiovnidca's Avatar
Default Re: simple question about oil (kasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kasso &raquo;</TD></TR><TR><TD CLASS="quote">if you have a tremendous amount of oil in the car (more than double the two dots), will the car eventually have problems starting? i thought it was the ignition so i put in the msd that was sitting around the house, and on cold starts, it always takes a while to start up. and white smoke is coming out of the exhaust.
btw. this is for 95 integra ls/v</TD></TR></TABLE>
It shouldn't keep it from starting. If it's overfilled bad it will smoke under acceleration. (3-4 quarts over)
White smoke is usually antifreeze. Blown headgasket maybe? That can cause hard starting. Can you do a compression or leakdown test?
Old Apr 27, 2005 | 05:55 AM
kasso's Avatar
Default Re: simple question about oil (Chiovnidca)
ya i think i ca get that done. hopefully its not my block. I just finished the ls/vtec. any other suggestions?
p.s. i have a CEL for coolant temp. sensor (code 6). also, when it does get started up, it backfires for about five minutes when i give it gas.
Old Apr 27, 2005 | 09:53 AM
kasso's Avatar
any other ideas? could it be bad timing?
Old Apr 30, 2005 | 12:06 PM
jarvis199's Avatar
Default Re: (kasso)
why dont u jsut drain some oil out
Old Apr 30, 2005 | 05:05 PM
kasso's Avatar
Default Re: (jarvis199)
been meaning to do an oil change but been too busy with school and work. same reason my oil press. gauge isnt hooked up.
Old Apr 30, 2005 | 06:23 PM
xEnderx's Avatar
Default Re: (kasso)
Yeah...it can caue problems to over fill the oil in a car. You run the risk of having improper oil clearences...esp in the rod and main bearings......lower viscosity oil lessens these chances though. &lt;shrug&gt; Why not jsut run the proper amount of oil?
Loverice
Jul 18, 2014 11:47 AM
Anthony2431
Jan 27, 2012 06:24 PM
MexiChriS
Sep 7, 2010 09:36 AM
94PearlWhiteGsr
Nov 1, 2004 03:18 PM
