Please help me find the compression!
Sorry If you guys are sick of seeing post like these but I really need to know my compression! My setup is
USDM ITR motor
JDM ITR pistons (20 over)
oem headgasket
flat face racing valves ( supertech to be exact)
milled head 25 thousandths
I really need help with this because I need to get the head milled and I dont know if 25 thousandths is too much! My friends tell me that it will most likely be at 12.3:1 is that close to even be correct?
Modified by five_ten1995 at 8:46 PM 4/27/2005
USDM ITR motor
oem headgasket
bump
he milled his head 25thou - what is the most you can mill your head? i was told my head was milled 30thou past the minimum spec (so i got a thick *** head gasket) but i never was able to find out what the minimum spec is... how much you can mill before the minimum is reached?
blowme
10
Jul 9, 2005 12:28 AM
Eluzion
May 27, 2004 05:46 AM
Blazin Si
15
Mar 8, 2004 04:25 PM
