question on k20
People have gone up to 2.34L with no problems.
In japan they also destroked a k24a crank in a k20a block with ctr b series pistons... gave them a 86 x 96 with around 2.3 L
TOP FUEL JAPAN is going to be selling that stroker kit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DTR-FAB »</TD></TR><TR><TD CLASS="quote">they have to be modifying the rod in some way because from what i know the B-series rod width is wider then the k-series..</TD></TR></TABLE>
I think they are widening the rod journals on the crank. The small journals can make for durability problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Innovation »</TD></TR><TR><TD CLASS="quote">You can open the journals up on the K series cranks to house a .935 width rod. By doing so you will have to take .001 off of the journal so its recomended to at least use a plastiguage to ensure your clearances are with in spec.
This will allow you to use any custom or off the shelf F20C, F22C, H22, H23 and H/F20C rod bearings rod with your newly reworked K20 or K24 crank
You can also offset grind the journal down to 1.770/1 increasing stroke + or - 3mm and run a custom or off the shelf B series rod
I would recomend re heat treating the jorunals if you were looking into doing this, just my opinion though
https://honda-tech.com/zero...age=4
Im not really sure why people are so eager to fork over $1000's for stroker kits they can make themselves for next to nothing ::shrugs::
</TD></TR></TABLE>https://honda-tech.com/zero...age=4
