Who has the most mods on their R???
Since we were doing the most stock. I thought that I would see if we could figure out who has the most mods. Here goes.....
MOTOR
JUN Type 3 Cams
JUN Valve Srings
JUN Retainers
JUN Cam Gears
JUN UL Flywheel
JUN Exhaust
JUN ECU
JUN Header
Mugen HeadGasket
JDM Spoon Engine Block
Spoon Oil Pump
AEM Intake
Extrude Honed Intake Manifold
65mm TB
Apexi Super AFC
Test Pipe
Split Second A/F Meter
Apexi Auto Timer
JDM Final Drive
SUSPENSION
Tein HA Coilovers
JDM Rear Strut Bar
Progress Camber Kit
LOOKS
Volk TE-37s
Window Tint
BRAKES
Project mu Brake Pads
I Know I put every little thing on there, but lets see what you guys can come up with.
[Modified by itr1236, 1:12 AM 2/1/2002]
MOTOR
JUN Type 3 Cams
JUN Valve Srings
JUN Retainers
JUN Cam Gears
JUN UL Flywheel
JUN Exhaust
JUN ECU
JUN Header
Mugen HeadGasket
Spoon Oil Pump
AEM Intake
65mm TB
Apexi Super AFC
Test Pipe
Apexi Auto Timer
JDM Final Drive
SUSPENSION
Tein HA Coilovers
JDM Rear Strut Bar
Progress Camber Kit
LOOKS
Volk TE-37s
Window Tint
BRAKES
I've got:
Cospetic Mods
Indeglo Gauges
Indeglo Needles
Indeglo Badges
Indeglo Whiper Sprayers
Indeglo Under body Kit (ie Neon)
APC Led Exhaust tip
Reative Sticker
Mugen Sticker
Nissimo Sticker
STI Sticker
Performance Mods
Front Mounted CIA
But I'm getting a turbo soon, realy, i sware, a t60
Also getting a spoon motor for the turbo
Suspension Mods
Cut Springs
Cospetic Mods
Indeglo Gauges
Indeglo Needles
Indeglo Badges
APC Led Exhaust tip
Reative Sticker
Mugen Sticker
Nissimo Sticker
STI Sticker
Performance Mods
Front Mounted CIA
Suspension Mods
Cut Springs
I'm sure I forgot some, but here's a few of my mods. I doubt I have the most stuff, however more isn't always better!
But then again my slogan is "when too much is just right."
Engine Mods:
Jackson Racing Supercharger
Honda CRV crank pulley (for more boost)
Unorthodox Racing Powersteering Pulley
Goodyear Gatorback reenforced belts (for charger)
Comptech icebox
Kamakaze Header (4-1 w/2.5" collector)
Custom Test pipe (2.5"-3"")
Thermal R&D exhaust (3")
Dynospot Racing Chipped ECU
APEXi S-AFC
J&S safeguard
DSR titanium retainers
RC 440cc Injectors
MSD Ignition SuperConductor Wires 8.5mm
NGK colder range sparkplugs
Toda Racing Cam gears (set to 1,0)
ACT Xtreme clutch disc
ACT Xtreme pressure plate
B&M Pro Edge shifter
B&M stabilizar kit
Spoon racing thermostate
Spoon magnetic oil plug
Spoon magnetic tranny plug
Spoon low temp fan switch
Spoon radiatior brackets
Spoon high pressure radiatior cap
Spoon oil cap
Spoon high pressure radiatior hoses
Wheel and Tire Mods:
Spoon 4-piston blue calipers (front)
Comptech/Goodridge SS lines
StopTech rotors (front)
Porterfield R4S front brake pads
Porterfield R4S rear brake pads
ATS Super blue brake fluid
Spoon light weight lug nuts (blue)
Enike wheel locks (blue)
Stock 15" R rims
Yokohama A032Rs (205x50xR15) heatcycled
Suspension Mods:
Tien type-HA coilovers w/pillow ball mounts
Comptech camber adjuster front
Comptech camber adjuster rear
Sparco 3" 5pt harnesses (driver)
Sparco 3" 5pt harnesses (passanger)
Sparco harness mount kit (for factory locations)
Speedware Harness Guide Bar (3pt w/mounts)
Custom front support for bumper and frame
Corner weighed, camber, toe, height, etc... adjusted & tuned
Audio Mods:
Premier Pioneer DEX-P1R
Panasonic VA707 7” flip out monitor
AlumaPro Power Cap 15 farad
MB Quart QM 218.61Q 6½" 2 Way Component Set
MB Quart PKC 116 6½" 2-Way Coaxial Speakers
Rockford Fosgate Power bd1000a1
Rockford Fosgate Power 800a4
Rockford Fosgate 12" Power DVC
Rockford Fosgate Punch Link
Rockford Fosgate 0&4gauge wires
Rockford Fosgate Interconnect wires
Rockford Fosgate remote bass link system
Sony Playstation 2
Custom video setup in rear ashtry location
(Subwoofer box is removed for racing)
Other Mods:
Honda JDM front-end conversion
Honda JDM OEM HID headlights
Honda JDM foglight button
Honda JDM R valve cover
Honda JDM shift boot
Honda JDM red "H" emblems
Honda JDM rim "H" emblems
Honda factory body kit
PIAA Jspec HID bulbs
C-Westin eyelid covers
Top Fuel front chin piece
MSD shiftlight
IO port camera mount
Auto Meter Air/Fuel Meter
Auto Meter Boost Gauge
Auto Meter Fuel Gauge
Auto Meter Oil Gauge
Auto Meter triple gauge pod
Brushed aluminum trim kit
Razo carbon touring pedals
3M UV window tint
Security System
[Modified by Rboosted717, 9:22 PM 2/1/2002]
But then again my slogan is "when too much is just right."Engine Mods:
Comptech icebox
APEXi S-AFC
J&S safeguard
RC 440cc Injectors
B&M stabilizar kit
Spoon oil cap
Stock 15" R rims
Suspension Mods:
Audio Mods:
Sony Playstation 2
Other Mods:
MSD shiftlight
3M UV window tint
Security System
I don't have an R....but heres my setup
Engine
Eagle/Endyn H-Beam Connecting Rods
Wiseco/Endyn Rollerwave Pistons 9:1 Compression bored to 84.5 MM (2.0 LITER)
Golden Eagle Iron Ductile Sleeves
Stainless Steel Valves Swirl Polished Black Nitride Coated
Portflow Titanium Retainers
Portflow Inner Valve Springs
Honda Integra Type-R Outer Valve Springs
Portflow Port & Polish & Deshroud Chambers to fit 84.5MM bore.
Crank Micro-polished & Balanced
Cometic 85MM Headgasket
GReddy TD05-18G Turbocharger
GReddy Intercooler with "GReddy" custom painted on it
GReddy Iron Cast Manifold
GReddy Oil Catch Can
GReddy Type S Blow Off Valve
GReddy Airinx Intake
Walbro 255LPH In-tank Fuel Pump
RC Engineering 550 CC Fuel Injectors
MSD 6AL Ignition System
MSD Modified Distributor Cap
MSD Chrome Blaster 2 Coil
Magnecor KV85 Competition Wires
NGK BKR7E Spark Plugs
AEM Silver Fuel Pressure Regulator
AEM Silver Fuel Filter
AEM Silver Spark Plug Wire Cover
JDM Type-R Red Valve Cover
Thermal Research & Development Stainless Steel 3" Exhaust
Carsound 3" Catalytic Converter
ACT Heavy Duty Pressure Plate /w Street Disc
Fidanza Flywheel
Hose Techniques Super Red Kit
Fluidyne Radiator
Flex-A-Lite Dual Slim Fans
Energy Suspensions Polyurethane Motor Mount Inserts
Handling/Braking
AEM Four Piston Caliper Big Rotor Brake Kit (Red) - front
Powerstop cross drilled & slotted rotors with AEM Nissin Brake Pads - rear
Goodridge Stainless Steel Braided Brake Lines
Neuspeed Front Sway Bar
Neuspeed Front Upper Strut Bar
Neuspeed Rear Sway Bar
Eibach Pro-Kit Springs
Koni Red Shocks
Ingalls Camber Kit Front & Rear
Electronics/Gauges
Speed Pro Bank 2 Bank Fuel Management System
GReddy Profec-A Boost Controller
GReddy Pearl White Turbo Timer
GReddy 52mm White Face Boost Gauge
Autometer Mini Shiftlight
B&M Fuel Pressure Gauge
Interior
Black Corbeau Carrera Seats
Black Corbeau 4 Point Harnesses
Type-R Titanium Shift ****
Clifford Concept 20 Alarm
Alpine 7949 Head Unit
Rockford Fosgate 40x4 Amp
MB Quart 3/4" Tweeters - Front
MB Quart 4" Woofers - Front
Exterior
Konig Rated-R 17" <-----Replacing with SSR Competition 17x7.5 this week.
Yokohama A520 215/40/17
Wings West W-Type II Body Kit
Fiber Images Carbon Fiber Hood
Integra Type-R Spoiler
1998+ Integra Tail Lights (No Amber turn signals)
Clear Bumper Lenses /w Euro-lite Bulbs
Shaved Trunk Key-hole
Shaved "ACURA" Emblem
Red "A" Emblems
Rear Windows Tinted
Engine
Fidanza Flywheel
Fluidyne Radiator
Handling/Braking
Koni Red Shocks
Electronics/Gauges
Interior
Exterior
Red "A" Emblems
Rear Windows Tinted
I want to play...
Compression Ratio: 14: 1 : 1
Max engine speed : 9600
ENGINE MODS
Custom JE prototype Forged Pistons
Custom Crower Titanium Rods
Crankshaft knife edged full counter
MCA stage 6 headwork
JUN Stage 3 Camshafts IN/EX
JUN Titanium Retainer
JUN Dual High Rev Valve Springs
AEM Cam Sprockets
AEM Power Pulley Kit
AEM Polished Fuel Rail
Custom 3 angle valvejob
Mugen Headgasket
ESSEX Fuel regulator
RC 370cc Injectors
MSD 6A
MSD Blaster 3 Coil
MSD Magnetic pulse stabilizer
Magnecor 8.5mm Wires
Larger VTEC solenoid
Modified Oil Pump
Greddy Oil filter adapter
Oversize Front Mount External Oil cooler
COMPUTER MANAGEMENT
Haltech E6K
INTAKE-EXHAUST
Custom updraft Individual Throttle Bodies
(??mm) & TWM velocity stacks (??mm)
Custom Filter and Airbox
Hytech custom lightweight stainless steel full race header
SUSPENSION
MUGEN rear sway bar
MUGEN N1 damper kit
Eibach ERS 800 lbs/in front
Eibach ERS 1200 lbs/in rear
Z-speed camber kit and customer rear
TRANSMISSION
Stock final gear 4.40
ATS Carbon Race Clutch
ATS Carbon Steel Race flywheel
ATS LSD 1.5 WAY
ATS LSD Oil
ATS close gear ratio set
INSIDE
Fully gutted
Sparco Rev Race seat w/ aluminum Sparco Brackets
Relocated optima Battery (Red)
NHRA Battery Box
Moroso Cutoff switch
Autometer exhaust Gas temperature
Autometer Oil Pressure
Autometer Oil Temperature
RAZO Race Pedals
FUEL
VP C14 Leaded Racing Fuel
OUTSIDE
Carbon Fiber hood (modified to fit ITB)
WHEELS/TIRES
ADVAN RG Gold 17 x 7.5
KUHMO V700 225 45ZR 17
BRAKES
Wilwood 6 pistons caliper (will order them as soon as Brian call me back)
12.2 slotted rotors
ALIGNMENT
Front camber -4 degree toe out 0.1
Rear camber -2.2 degree toe in 0.05
PLANNING MODs
Wilwood rear 2 pistons caliper and slotted rotors
16g. Fuel cell
Moroso Oil pan
Rollcage, cut floor board
EST WHP
245+
Engine by
Michael (MCA Motorsports)
TOW TRUCK
2001 Silver F150 5.4 Supercrew
WHEELS/TIRES
20” 2PCs MHT
Goodyear 20 55R 275
VISUAL AUDIO
Pioneer AVX-P7300DVD In Dash Full motorized Monitor
Pioneer AVM-P8000R Virtual Theater Graphical User Interface Audio/Video Master Unit
Sony Playstation 2
_______
97 R 58 ( full full race)
01 F150 5.4 Supercrew ( tow truck)
ENGINE MODS
AEM Cam Sprockets
Mugen Headgasket
RC 370cc Injectors
MSD 6A
MSD Blaster 3 Coil
Modified Oil Pump
COMPUTER MANAGEMENT
Haltech E6K
INTAKE-EXHAUST
SUSPENSION
MUGEN rear sway bar
MUGEN N1 damper kit
TRANSMISSION
ATS LSD 1.5 WAY
ATS LSD Oil
INSIDE
Fully gutted
NHRA Battery Box
RAZO Race Pedals
FUEL
OUTSIDE
WHEELS/TIRES
BRAKES
12.2 slotted rotors
ALIGNMENT
PLANNING MODs
16g. Fuel cell
Moroso Oil pan
EST WHP
245+
Engine by
TOW TRUCK
WHEELS/TIRES
20” 2PCs MHT
Goodyear 20 55R 275
VISUAL AUDIO
Sony Playstation 2
_______
Here's Mine
Engine Mods:
Mugen Cold Air Intake
A&J Racing taper-bore throttlebody
Spoon 4-2-1 Header
Spoon test pipe
JDM Mugen B-pipe and twin-loop exhaust
Custom mapped Mugen N1 ECU
King Motorsports ECU harness
81.5 mm Endyn Rollerwave Pistons
Forged Eagle connecting rods
Overbored block
Custom balanced rotating assembly
Titanium retainers
Jun valvesprings
Toda Spec B Cams
Nology Hotwires
Nology hi-perf blaster coil
MSD distributor cap
Spoon Racing plugs
Unorthodox Racing Cam gears
Mugen 3-puck racing clutch disc & pressure plate
Spoon Flywheel
Spoon magnetic oil plugs
Mugen high pressure radiatior cap
OMP rising rate fuel pressure regulator
Type One Grounding system
SMC SS lines
Brembo rotors (front)
Porterfield R4 front and rear R4S brake pads
Motul 600 brake fluid
Mugen lug nuts
Mugen 16" MF-10s 50mm offset
Mugen 15" MF-10s (for track tires)
Toyo Proxes RA-1 (205x50xR15) heatcycled (track)
Pirelli P7000Z 225/40-16s (street)
Suspension Mods:
Ground Control coil-over sleeves
Eibach ERS springs 400# F / 600 # R
Mugen 26 mm rear bar
Spoon rear strut bar
OMP 3" 5pt harnesses
OMP Carbon-Kevlar "Grip" racing seats
OMP FIA-approved 6-point roll cage (going in now)
Mugen adjustable rear wing
Custom tuned alignment and corner weighted
Audio:
Alpine 240 W headunit
Eclipse 2-channel amp
Illusion Audio Carbon Series 6.5" front component drivers
Boston Acoustics 6.5" rear drivers
Bazooka 10" subwoofer (comes out for track days)
Alpine 8063 Alarm with
Alpine Mobile Mayday GPS security system
Other Mods:
OMP Formula steering wheel
Acura OEM bodykit
PIAA Superwhite headlights
Acura OEM foglights
Greddy Air/Fuel Meter
Auto Meter Oil Temp Gauge
Auto Meter Oil Pressure Gauge
Auto Meter Bezel gauge mount
Comptech carbon fiber trim kit
Mugen pedals
3M UV window tint
Engine Mods:
Spoon 4-2-1 Header
Spoon test pipe
Overbored block
Titanium retainers
Jun valvesprings
Toda Spec B Cams
Nology Hotwires
MSD distributor cap
Spoon Racing plugs
Spoon Flywheel
SMC SS lines
Mugen lug nuts
Suspension Mods:
Audio:
Other Mods:
Acura OEM bodykit
Acura OEM foglights
Mugen pedals
3M UV window tint
