Car wont spark?!?
Old Apr 26, 2005 | 07:57 PM
SiRRedneck's Avatar
Default Car wont spark?!?
well this is the problem, i have a full Z6 swap in my crx, i used the JKOBD ecu harness and my stock engine harness, i have everythin wired up, i have been workin on this dam thing for like 5 days now and we cant get the engine to spark. i have a MSD external coil cap running to the external coil(obviously). i have power thru the dizzy to the coil and from the coil to the cap but nothing past that, i had bought a cheap rotor from NAPA, it doesnt seem to fit right, it seems taht its not making contact with the posts in the dizzy, if some one were to know whats wrong that would be great,
P.S. i already changed the ICM with a workin one, and im runnin the stock P28 ecu. is that helps
Old Apr 27, 2005 | 09:58 AM
SiRRedneck's Avatar
Default Re: Car wont spark?!? (SiRRedneck)
bimp
Old Apr 27, 2005 | 01:03 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRRedneck &raquo;</TD></TR><TR><TD CLASS="quote">i have power thru the dizzy to the coil and from the coil to the cap but nothing past that, i had bought a cheap rotor from NAPA, it doesnt seem to fit right</TD></TR></TABLE>
It sounds like you already know what the problem is. Have you tried the right rotor?
Old Apr 27, 2005 | 03:04 PM
SiRRedneck's Avatar
Default Re: Car wont spark?!? (drdisco69)
well i bought a new Rotor, Cap, ICM, have following grounds: batt to tranny, batt to body, batt to thurmo, valve cover to body. i have fuel comin out like crazy, so i know the injectors work and have no problem there, i have power to the ICM and then to the coil and on the coil tower, but no spark. if anyone knows what im overlooking it would be a great help, been tryin to get spark for 5 days now,
Old Apr 28, 2005 | 02:46 AM
SiRRedneck's Avatar
some one must know, this isent an odd swap,
Old Apr 28, 2005 | 05:37 PM
SiRRedneck's Avatar
Anyone? ive tryed everythin, the harness is wired to spec, from both 88 crx si and 95 civic si Honda servince manuals
torr
Apr 24, 2024 09:35 AM
95blackEG
Dec 24, 2008 07:59 PM
418whpturboD
Mar 13, 2008 07:29 PM
tRex99
Nov 7, 2004 05:07 PM
-[95cxhatch]-
Dec 30, 2003 02:02 AM
