stock clutch or exedy oem replacement
Old Apr 26, 2005 | 07:06 PM
rice is nice's Avatar
Default stock clutch or exedy oem replacement
Its about time I get a new clutch. This is a 89 civic SI, and will only be seeing bolt on upgrades. Should I buy a honda clutch and pressure plate, or just buy one of those execy kits on ebay for $100 bucks?
Old Apr 26, 2005 | 07:07 PM
dr_latino999's Avatar
Default Re: stock clutch or exedy oem replacement (Killa-X)
Either or will work for stock nifty-ness.
Old Apr 26, 2005 | 08:29 PM
FalkenSiR's Avatar
Default Re: stock clutch or exedy oem replacement (dr_latino999)
Those exedy clutches seem to be good quality. Haven't heard of any complaint. I sold one to a friend and it's been holding up awesome
....yes he races it.
Old Apr 26, 2005 | 08:34 PM
90LSpimpin's Avatar
Heres what i did, I've got an 89 si. Bought a Act prolite flywheel for 90+ clutch , and Exedy Oem replacement clutch for 92+. The 90+ cltuch is slightly bigger than the 89 which is a gain in itself, and the exedy clutch is supposed to have like a 33% gain over stock. I love the combo, grips pretty damn good. We'll see how it holds up when i'm boosted in the next few weeks. Good luck!
Old Apr 26, 2005 | 11:26 PM
JonGP4's Avatar
Default Re: stock clutch or exedy oem replacement (89SiPimpin)
most OEM honda clutchs are made by Exedy.. your buying the same exact product, OEM or exedy
if your running 25% more power then stock.. i'd recommend the exedy stage 1 organic..
Old Apr 27, 2005 | 04:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89SiPimpin &raquo;</TD></TR><TR><TD CLASS="quote">Heres what i did, I've got an 89 si. Bought a Act prolite flywheel for 90+ clutch , and Exedy Oem replacement clutch for 92+. The 90+ cltuch is slightly bigger than the 89 which is a gain in itself, and the exedy clutch is supposed to have like a 33% gain over stock. I love the combo, grips pretty damn good. We'll see how it holds up when i'm boosted in the next few weeks. Good luck!</TD></TR></TABLE> I really don't know how much power an OEM replacement is going to like; if you lay it on light you may have no problem but under torque loads higher then it is rated for it will be hasta luego clutch.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonGP4 &raquo;</TD></TR><TR><TD CLASS="quote">most OEM honda clutchs are made by Exedy.. your buying the same exact product, OEM or exedy
if your running 25% more power then stock.. i'd recommend the exedy stage 1 organic..</TD></TR></TABLE> The ones I have seen off motors that still had OEM clutches said Dankin, is that a subsidiary of Exedy?
Old Apr 27, 2005 | 08:37 AM
eyesniper's Avatar
when i swaped mine out i went with the exedy stage 1 organic. i tell you when it grabs it grabs. i love it and so far i havent had any problems with it.
Old Apr 27, 2005 | 10:32 AM
JMac76913's Avatar
Default Re: (eyesniper)
yeah, same here....... when i swapped my stock clutch out, i got a exedy stage 1 and i love it
Go For The EXEDY
Old Apr 27, 2005 | 10:43 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: (EK_Coupe)
im rocking a exedy replacement clutch off ebay in both of my G rides... a 97 GSR, and a 92 hatch with a turbo.. can't beat it.. even on the turbo, that bitch still grabs.
Old Apr 27, 2005 | 01:58 PM
onePOINTsix's Avatar
Default Re: (Built B16A)
i've run a OEM Replacement Exedy and i'm currentally rocking a Exedy Stage 1 on my CRX, great quality clutches. I have 2 different friends that rock them on their Type-Rs and I know people that have had great results with them even on a turboed car... they get a big from me
Old Apr 27, 2005 | 02:53 PM
.Unknown.'s Avatar
Default Re: (onePOINTsix)
I definately need a CLutch.. Those Clutches i see on Ebay the " Exedy " clutch. for like 75-85.00 are they worthy to buy. Kinda looked wierd being so Cheap. Any input on that? I'll wait to buy... until i get a response. Also if you bought one from Ebay. What was the Seller's Name?
Old Apr 27, 2005 | 07:21 PM
Kwicko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> The ones I have seen off motors that still had OEM clutches said Dankin, is that a subsidiary of Exedy?</TD></TR></TABLE>
Yup. Exedy is the aftermarket brand name Daikin uses. I've been using them for about 5-6 years on various Hondas of mine, and had no problems with them at all. And when you open up the Exedy box, you'll see the Daikin logo on the parts.
Mike
Old Apr 27, 2005 | 08:30 PM
Built B16A's Avatar
Default Re: (.Unknown.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Unknown. &raquo;</TD></TR><TR><TD CLASS="quote"> I'll wait to buy... until i get a response. Also if you bought one from Ebay. What was the Seller's Name?</TD></TR></TABLE>
thats what i bought.. my civic clutch was like 80 bucks.. my integra one was like 100. 80-SOHC, 100-DOHC.. great clutch..
i belive the seller was ... hrmm, (goes to log into ebay)
"gripforce-clutches " thats who i got my clutch off ebay from.
EXEDY clutches
Old Apr 27, 2005 | 09:10 PM
.Unknown.'s Avatar
Thanx.... Time for a Clutch This Weekend. =]
Loganp98
Honda Civic (2006 - 2015)
Sep 7, 2017 04:13 AM
jwhezzy2003
Aug 28, 2008 08:46 AM
Iceberg90
Oct 7, 2007 07:15 PM
-[95cxhatch]-
Aug 4, 2003 11:06 PM
PoweredByPrelude
Mar 5, 2003 10:11 AM
