IACV Problem and O2 Sensor Problem
Old Apr 26, 2005 | 06:30 PM
civic919900's Avatar
Default IACV Problem and O2 Sensor Problem
Ive got a 2000 Civic EX w/ a 99 D16Y8, the engine light comes coming on with the same 2 codes, One code is for the idle air control valve, i replaced it from my old 2000 D16Y8 motor because it was throwing the code with the 99 IACV. Still throwing the code. Car idles extremely low, timing is right, all new tune up parts still no luck. Also 02 Sensor (Bank 1) Not sure if this is the 02 sensor in the headers or after the cat. I have pacesetter headers for a Z6 and the O2 sensor hole on the headers was up farther so i did a nice wiring job using heat shrinking waterproof connectors the extend the wiring. i also have a high flow cat so im not excatly sure whats going on, my car should be running better than it is. All these problems occur after putting the new motor in.
Old Apr 26, 2005 | 07:54 PM
Above6K's Avatar
Default Re: IACV Problem and O2 Sensor Problem (civic919900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic919900 &raquo;</TD></TR><TR><TD CLASS="quote">Ive got a 2000 Civic EX w/ a 99 D16Y8, the engine light comes coming on with the same 2 codes, One code is for the idle air control valve, i replaced it from my old 2000 D16Y8 motor because it was throwing the code with the 99 IACV. Still throwing the code. Car idles extremely low, timing is right, all new tune up parts still no luck. Also 02 Sensor (Bank 1) Not sure if this is the 02 sensor in the headers or after the cat. I have pacesetter headers for a Z6 and the O2 sensor hole on the headers was up farther so i did a nice wiring job using heat shrinking waterproof connectors the extend the wiring. i also have a high flow cat so im not excatly sure whats going on, my car should be running better than it is. All these problems occur after putting the new motor in.</TD></TR></TABLE>
Did you clear the old code before starting it back up?
Old Apr 26, 2005 | 08:06 PM
civictildeath's Avatar
o2 sensor Bank 1 is the one in the header
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Above6K &raquo;</TD></TR><TR><TD CLASS="quote">Did you clear the old code before starting it back up?</TD></TR></TABLE>
definately a must
did you wire the 2 of the same color wires back correctly??
Old Apr 27, 2005 | 06:10 AM
Yea I cleared the codes before restarting it, yea i thought i did a good wiring job but ill have to check it again.
novotm
Honda Civic (2001 - 2005)
Jun 20, 2010 09:21 AM
Silver89crx
Dec 20, 2007 04:10 PM
jorober5
Feb 9, 2006 04:40 AM
4inspeed
Jan 7, 2004 07:34 PM
