where is the pcv valve?
Old Apr 26, 2005 | 04:24 PM
user 98292739's Avatar
Default where is the pcv valve?
i did a search and didnt really reconize where it was according to the diagrams people are giving....does anyone have a real motor bay picture of where this valve is? reason why i ask is because someone said it might be clogged thats why i only burn oil sometimes.
Old Apr 26, 2005 | 04:30 PM
gutted-dx's Avatar
It is on top of the intake manifold, and it should have a hose coming up from below
Old Apr 26, 2005 | 04:50 PM
Tyson's Avatar
Default Re: where is the pcv valve? (LoCoReX)
look between the intake manifold runners of #1 and #2 cylinders. its got a hose from the top of the intake manifold. just grab it and pull it off, it just pops off. replace or clean with some brake cleaner.
its probably not the reason youre burning oil tho. it just gets clogged faster when you are burning oil.
Old Apr 26, 2005 | 04:55 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: where is the pcv valve? (Tyson)
Old Apr 27, 2005 | 01:23 PM
ha i just found it today after looking behind the motor....i have no idea why i am burning oil then.....head is freshly rebuilt....getting 200 psi across the board....someone just mentioned that so i mind as well try to see if that is it.
Old Apr 27, 2005 | 01:26 PM
sporkcrx's Avatar
Default Re: (LoCoReX)
To see if it's good, just take it off and shake it. If you can't hear a clicking or clunking around, buy a new one (cheap) When they go bad you can start blowing oil past your engine seals.
42aRanger
Jul 12, 2013 01:29 AM
b16a4
Aug 7, 2007 08:17 PM
Parada
Feb 28, 2007 09:53 AM
bootlegtrader
Sep 19, 2005 11:46 AM
90accord1
Dec 13, 2001 06:58 PM
