JDM EG Cluster Problem
Old Apr 26, 2005 | 01:57 PM
GSR_EG6's Avatar
Default JDM EG Cluster Problem
ok all of a sudden my cluster is starting to read 0 rpm when my car is idleing, but when i rev it up it works, but its supose to read 800rpm on idle, whats wrong with it?
Old Apr 26, 2005 | 02:47 PM
GSR_EG6's Avatar
anyone??
Old Apr 26, 2005 | 03:12 PM
germz's Avatar
Default Re: JDM EG Cluster Problem (GSR_EG6)
mines is like that too....off by 400 rpm or so.
but sometimes it reads fine.
Old Apr 26, 2005 | 03:23 PM
GSR_EG6's Avatar
anyway to fix this, i kinda want it to read good so i dont over rev or anything like that.
Old Apr 26, 2005 | 04:06 PM
germz's Avatar
Default Re: (GSR_EG6)
mines works fine after the motor is warm up.
it only idles on 0rpm when its cold....try checking the connections, make sure
none of the pins are loose from installation
Old Apr 26, 2005 | 04:14 PM
GSR_EG6's Avatar
hmmm, it worked fine b4 tho, but ill check tommrow, to late now
Old Apr 27, 2005 | 11:15 AM
GSR_EG6's Avatar
doesnt anyone else know anything about this???
Old Apr 27, 2005 | 11:35 AM
Mario.'s Avatar
I've had my needle been off before... it'll read like 1200-1500rpms when my AFC clearly shows it's 750rpms. Usually when I hit VTEC it will correct itself. Seems like the needle is sticky.
Old Apr 27, 2005 | 11:57 AM
ciriz's Avatar
ive been told by many, that as our cars get older the rpms tend to go off track a little, either they fall behind, the motor dies out, or something happens. mine did that for a while, and would get stuck at 4k, then re align its self as soon as vtec kicked in. weird, as long as when you are driving the rpms are correct, you should be okay. DONT TRY AND PULL OF THE NEEDLE AND REALIGN IT...wont work i promise.
Old Apr 27, 2005 | 06:49 PM
GSR_EG6's Avatar
well it worked perfect b4, so i didnt want to take it off, but i donno if its really the true rpm that its reving at when im driving, it seems like it but im not 100% sure.... i want it fixed
ham
Feb 25, 2007 08:19 PM
eg5
May 17, 2006 04:26 AM
crashzerothree
Apr 4, 2006 07:45 AM
USDM EG
14
Mar 24, 2005 09:05 AM
