h22 into ek ex help
hi alll i have a 1993 jdm h22 engine wiich i have fitted usiing hasport mounts into a 96 ek ex. i will be using skunk 2 obd1 to 0bd2 converson harness fro the ecu wich is a p13 .
the problem i am having is the wirring i have read that you have to swap and extend most conectors onto the original ex harness. but i have noticed the distributor is differernt plug lay out to the h22 as it has 2 plugs rather than the ex wich has one.
also do i need the injector resitor box? if so where does it go as the ex harness does not have a plug for it
any help would be apreciated
thanks
thanks
