Temperature sender and sensor problem
Old Apr 26, 2005 | 07:33 AM
Dual_Phart_cans's Avatar
Default Temperature sender and sensor problem
Okay, my radiator fan and my temp. guage isnt working, in the haynes manual it says to ceck the wires for shortages . . . how do i do this? the coolant temperature sender has only one wire and the manual says to ground it, how do i do that and how would i check that wire, and the wires from the coolant temperature sensor for shortages . . . .?
Default Re: Temperature sender and sensor problem (Dual_Phart_cans)
eh, does that makee any sense? =/
Old Apr 26, 2005 | 08:01 AM
Luserkid's Avatar
You should have 2 sensors. One that goes where the upper rad. hose meets the engine, or it could also be on the side of the head depending on your motor. That one tells you when your car is heating up or engine temp. That is a 2 wire pin
Next is your fan switch. If you follow your lower rad. hose you will see another opening connected to a tube in the back of your motor. On that is another plug, which tells your fan to turn on. That as well is a 2 wire pin plug.
If your fan doesnt turn on as well i believe you just blown a fuse. Check all your fuses and see which is blown before you do wiring since it seems like you have NO clue about electrical.
Old Apr 26, 2005 | 11:28 AM
Ive checked all my fuses, so how wouldi g o about cheking wires and the actual sender & sensor them selfs? by the way, its a 1992 civic hatch DX with the factory d15
Modified by Dual_Phart_cans at 1:13 PM 4/26/2005
NAV_GUNZ
Oct 14, 2008 09:36 PM
CRseXy
Apr 25, 2005 08:29 AM
deftones0817
Oct 17, 2004 06:53 PM
scrubachu
Aug 28, 2004 07:21 AM
groundedcivic91
Mar 26, 2004 04:09 PM
