Suspension & Brakes Theory, alignment, spring rates....
Bottoming out on small animals
Old Apr 26, 2005 | 03:57 AM
w's Avatar
w
Default Bottoming out on small animals
I've had my 96 civic ex for about 3 months now. The last owner claimed to have skunk2 coilovers on it. I keep forgetting to look and check but anyways. I bottom out over everything. Little bumps on bridges, little bumps when they repave the road, and any form of irreguality in pavement. The car is lowered about 1.5-2 inches on them.
Here's the question is this just normal skunk2 on a civic and i need to man up and take it? Or is something screwed up and i need to replace. Im just wondering if this is normal i guess.
Old Apr 26, 2005 | 06:27 AM
yudalicious's Avatar
Default Re: Bottoming out on small animals (hondadude96)
lower the car a bit more for optimal handling, 2.5-3 inches would be best for handling on a Civic. Don't owrry about the bottoming out, the roads are just bad, once you get on a track you'll be flying.
Old Apr 26, 2005 | 06:36 AM
AnToNy's Avatar
I have Skunk2's and lowered about 3 inches. I don't bottom out on anything...
Something is wrong with your setup, you shocks are probably blown and need replacing.
Old Apr 26, 2005 | 07:22 AM
w's Avatar
w
Default Re: Bottoming out on small animals (jaedaSC)
never been to the track and probably not likely to go anytime
Old Apr 26, 2005 | 11:08 AM
Dave421's Avatar
Default Re: Bottoming out on small animals (yudalicious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yudalicious &raquo;</TD></TR><TR><TD CLASS="quote">lower the car a bit more for optimal handling, 2.5-3 inches would be best for handling on a Civic. Don't owrry about the bottoming out, the roads are just bad, once you get on a track you'll be flying.</TD></TR></TABLE>
What? 3" on a civic equals no suspension travel without doing something to correct it (i.e. extended top hats, adjusting fork to hold shock lower, etc.).
What exactly do you mean bottoming out? Is the car hitting the road or is the suspension bottoming out? If it's the car, you're either lowered more than 2.5", you have a body kit/lip, or something else is too low on the car (header/exhaust). If it's the suspension then you're probably riding on blown struts as well as possibly having the car too low. May have full length bumpstops on it as well which can contribute but is better than no bump stop.
Old Apr 26, 2005 | 11:21 AM
w's Avatar
w
Default Re: Bottoming out on small animals (Dave421)
Whats happening is when i hit the slightest of bumps its like BAM!!! And hits through the whole car. No body to ground contact. Its only lowered 1.5-2 inches.
Old Apr 26, 2005 | 11:55 AM
POE's Avatar
POE
maybe u are bottoming out on your bumpstop. maybe they did not cut it at all.. , also if they are stock shocks, its prob most likely they are worn or blown or close to being blown, Time to invest in some aftermarket shocks.
Old Apr 26, 2005 | 12:35 PM
gabebauman's Avatar
Default Re: (POE)
You should add Aftermarket Shocks to your WTB list noted in your signature.
Old Apr 26, 2005 | 01:03 PM
w's Avatar
w
Default Re: (gabebauman)
good idea, I know this has probably been covered a million times but im running a street setup daily driver stock for now but soon to be turbo in the fall. I need a streetable yet cheap if possible setup. Any reccomendations?
Old Apr 26, 2005 | 01:11 PM
gabebauman's Avatar
Default Re: (hondadude96)
Got my KYB AGX's from tirerack.com
http://www.tirerack.com/suspen...&y=15
Old Apr 26, 2005 | 03:46 PM
w's Avatar
w
you likin them?
Old Apr 26, 2005 | 04:07 PM
gabebauman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude96 &raquo;</TD></TR><TR><TD CLASS="quote">you likin them?</TD></TR></TABLE>
Two years...and goin stong. First had them on Sprint sport springs with 2in drop now with Skunk2 coilovers with roughly 2.5" drop.
Newbster91
Oct 16, 2013 09:07 AM
cbaber
Oct 21, 2009 09:45 AM
spaceman00
11
Mar 18, 2007 11:26 AM
SIcoup
Aug 18, 2003 08:44 AM
civic_tko
Nov 13, 2002 12:52 PM
