boosted 99 civic si parts over to 88-91 crx?
i have a jrsced 99 si and im putting it back to stock for the wifey. im going to pick up a 88-91 crx si and put a boosted b16 swap in it and I have a few questions.
will my 255 walbro fuel pump transfer over to the crx?
i know my PnH RC 550s will transfer right over, but, will running my hondata s2b on my p28 ecu be fine?
will my skunk front camber transfer over?
can my skunk short shifter transfer over?
i know my clutchmaster3 will not transfer over, but, will my 8 lbs flywheel from my b16a2 si transfer to the b16a1? also, is it worth the trouble to convert the cable tranny to hydro, just so i can put the clutchmaster3 in?
TIA.
TIA.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spidermancivic »</TD></TR><TR><TD CLASS="quote">i have a jrsced 99 si and im putting it back to stock for the wifey. im going to pick up a 88-91 crx si and put a boosted b16 swap in it and I have a few questions.
TIA.</TD></TR></TABLE>
injectors will work just change plugs, and convert to obd1.
Skunk camber wont transfer over.
Shifter will.
Hydro conversion is the way to go. The flywheel will bolt up to a first gen b16 just have to use a 90-91 integra clutch, if using a cable tranny.
Shifter will.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91B16HF »</TD></TR><TR><TD CLASS="quote">The fuel pump should work.</TD></TR></TABLE>
so why do they sell different pumps for different applications?
