squeeking rubber sound out of my right from wheel-well...
Old Apr 25, 2005 | 09:21 PM
FakeJDMEF8's Avatar
Default squeeking rubber sound out of my right from wheel-well...
i just recently got a squeeking sound coming from my front passenger side wheel well. it sounds like something is rubbing but i cant seem to find out what is squeeking or what is causing it....any ideas??? the axels are new and not busted....wheel bearing?
Old Apr 25, 2005 | 09:34 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: squeeking rubber sound out of my right from wheel-well... (FakeJDMEF8)
could be that, could be the squeelers on your brakes telling you you need new pads. brakes are cheap, check those out first.. if that isnt it, then tear apart the knuckle cause that is probably the problem
Old Apr 25, 2005 | 09:52 PM
Civic138's Avatar
Default Re: squeeking rubber sound out of my right from wheel-well... (sanimalp)
i have the same problem, right whell well and all, i looked at everything thing and found out my bushings are worn out,so my advice would be to replace your 15 your old rubber bushings with poly ones.
Ritchie
13
Jan 14, 2009 10:40 AM
gsl_05
Jul 25, 2007 04:47 PM
rkrone
Dec 2, 2006 02:25 PM
ND40oz
Nov 27, 2006 06:10 PM
Funkin Flux
Jan 25, 2006 05:43 PM
