my dyno LS/VTEC
finally got it dyno. the car has never been tuned!
mods:
- B18B1 block
balanced bottom end
ITR piston
shot peened rods
micro polished crank
arp rod bolts
ITR oil pump
ITR water pump
new bearings
new rings
all new seal
Head-
b16a1 head
ITR intake mainfold
Skunk2 stage 2 cams
stock cam gears
ITR valve train
ITR throttle body
stock injectors
GSR Tranny
CM stage 2 clutch
Stock flywheel
DC sports 4-1 header 2.5 collector
HKS Hyper muffler with Apexi
2.35in piping
Redline performance chipped p28 ecu
what do you guys think?
mods:
- B18B1 block
balanced bottom end
ITR piston
shot peened rods
arp rod bolts
ITR oil pump
ITR water pump
new bearings
new rings
all new seal
Head-
b16a1 head
ITR intake mainfold
Skunk2 stage 2 cams
stock cam gears
ITR valve train
ITR throttle body
stock injectors
GSR Tranny
CM stage 2 clutch
Stock flywheel
2.35in piping
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smRs2000 »</TD></TR><TR><TD CLASS="quote">havent tuned it yet it was just a baseline. yea i just got a vtec contorl and i set the vtec at 6300 and it pulls all the way now. </TD></TR></TABLE>
Looks like your a/f ratio is pretty well tuned to begin with... As for the results, I say they are pretty low. I put down the same numbers, only more torque with a B18C1 with stage one cams and a stock intake, and with a **** poor a/f ratio curve on the dyno... no tunning.
is type r valve train good enough for skunk 2 stage 2s???? i thought it was recommended to upgrade the valve train if your getting passed stage 1
correct me if i'm wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragonz04 »</TD></TR><TR><TD CLASS="quote">is type r valve train good enough for skunk 2 stage 2s???? i thought it was recommended to upgrade the valve train if your getting passed stage 1
correct me if i'm wrong</TD></TR></TABLE>
No. Do not run r valvetrain on stage 2's. You will get coil bind.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragonz04 »</TD></TR><TR><TD CLASS="quote">maybe that's why w/ the low numbers</TD></TR></TABLE>
Coil bind is going to destroy either the springs, retainers, rockets, cam lobes, or all of the above
Solo2Vtec
Nov 11, 2004 02:56 PM
mtber
30
Apr 4, 2004 03:13 PM
